Skip the data cache initialization if we are a secondary processor.
The bug was introduced by e164df5e33608576443b4cd5923a9046358ee773 and
did not show up in tests using Qemu since the data cache behaviour is
not emulated.
Calling the memory FLASH and EXTRAM instead of FLEXSPI and SDRAM makes
it simpler to support other types of external RAM. This patch also
removes some of the calculations and improves names and documentation to
avoid pitfalls. It removes a unnecessary memory definition.
Update #4180
Update #4180
Fix an off by one error.
Update #3269.
This define is no longer used.
Update #3269.
Use BSP_INTERRUPT_VECTOR_COUNT instead of BSP_INTERRUPT_VECTOR_MAX.
Update #3269.
Assert BSP_INTERRUPT_VECTOR_MAX + 1 == BSP_INTERRUPT_VECTOR_COUNT.
After building all BSPs with this patch, BSP_INTERRUPT_VECTOR_MAX can be
removed and replaced by BSP_INTERRUPT_VECTOR_COUNT. The
BSP_INTERRUPT_VECTOR_COUNT allows a default implementation which supports no
interrupt vector at all. Using COUNT instead of MAX may avoid some
interpretation issues, for example is the maximum value a valid vector number
or not.
Update #3269.
Remove BSP_INTERRUPT_VECTOR_MIN and unconditionally let interrupt vector
numbers start with zero.
The BSP_INTERRUPT_VECTOR_MIN == 0 invariant was tested by the previous commit
and building all BSPs.
Update #3269.
Update #4202.
Also updated licenses.
Closes #4400
Updates #3899
The EDMA is intialized so make sure the the clock is initialized too.
Update #4180
The sizes are configurable via fuses or per software via some registers.
At the moment the registers are not changed. Changing the registers
destroys data stored in the RAM areas (like application code or data).
So either the fuses or some bootloader should be used to set them before
the application starts.
This also adds an OCRAM only linker command file.
Update #4180
Add addresses and interrupts for most internal peripherals to the dts.
The additional aliases make it possible for an application to easily
access these informations.
Update #4180
Remove symbols that would be necessary for overlays and decrease padding
that would be necessary for adding stuff during run-time.
Update #4180
Update #4180
Update #4406.
Add a parameter to _TOD_Validate() to disable the validation of the
ticks member.
There are two reasons for this change. Firstly, in
rtems_task_wake_when() was a double check for time_buffer == NULL (one
in rtems_task_wake_when() and one in _TOD_Validate()). Secondly, the
ticks member is ignored by rtems_task_wake_when(). This was done with a
write of zero to the ticks member and thus a modification of the
user-provided structure. Now the structure is no longer modified.
Using a mask parameter is quite efficient. You just have to load an
immediate value and there are no additional branches in _TOD_Validate().
Close #4406.
This patch fixes bug #4403. Directives
* rtems_timer_fire_when()
* rtems_timer_server_fire_when()
* rtems_task_wake_when()
are documented to return RTEMS_INVALID_ADDRESS when their time-of-day
argument is NULL. But actually they return RTEMS_INVALID_CLOCK. To fix
the issue this patch changes _TOD_Validate() to return a
status code instead of just true/false.
Close #4403
Update #3866.
Change the ARMV7_CP15_START_WORKSPACE_ENTRY_INDEX value to be in line
with the workspace entry in ARMV7_CP15_START_DEFAULT_SECTIONS.
Close #4395.
Uses configured millisecond per ticks
Refactored the i2c driver to parse register values from the device
tree rather than hardcoding them. But still the clocks have to
initialized manually.
Set the Main Stack Pointer (MSP) to the ISR stack area end just in case
we run using the Process Stack Pointer (PSP). This helps if
applications are started by a boot loader.
This now uses rtems_clock_get_uptime_nanoseconds
to calculate the uptime ticks in milliseconds.
Update #3850
Update #4372
Update #4372
The following files have been ported
1) ti_pinmux.c
2) ti_pinmux.h
3) am335x_scm_padconf.c
4) am335x_scm_padconf.h
Update #3784
Detects the SOC type using FDT and also replaces the ti_cpuid.h
header in FreeBSD with custom one.
Makes it simpler to access the QTMR in an application via a FDT name or
link in an application specific FDT entry.
Change license to BSD-2-Clause according to file histories and
re-licensing agreement.
Update #3899.
This fixes an issue with the latest tool chain which adds the default
linker script in the endfile specification.
Update #3250.
Sort alphabetically.
GCC 11 uses DWARF 5 by default.
For i.MX7 U-Boot initializes the system counter. On i.MX6 Barebox is
often used which doesn't initialize the counter. With this patch, we try
to auto-detect whether the counter is initialized or not and do the
initialization ourself if necessary.
Closes #3869
This allows an application to get the registers of the LPSPI. That is
usefull for applications that want to use DMA for a very specialized and
highly optimized communication.
Update #4180
Also currently no driver uses these numbers, it is usefull for
applications that want to use the DMA.
Update #4180
Note: The changes have been done with portability in mind. The driver
should (in theory) be able to replace the original one in the MPC BSPs
too. For full compatibility an adaption layer and especially a test
would be necessary. Because both are missing, don't integrate it into
the MPC BSP now.
Update #4180
If spi or i2c slaves are "connected" to the spi or i2c bus, the device
tree compiler complains if the busses are not named spi or i2c.
Update #4180
This allows applications to individually provide configuration
structures.
Update #4209.
structures.
Update #4209.
