path: root/bsps/arm/tms570 (follow)
* bsp_specs: Delete last remnants of these.Joel Sherrill2021-11-291-0/+0
| | | | Updates #3937.
* build: Remove old build systemSebastian Huber2021-09-211-63/+0
| | | | | Close #3250. Close #4081.
* bsps/irq: bsp_interrupt_facility_initialize()Sebastian Huber2021-07-271-3/+1
| | | | | | Do not return a status code in bsp_interrupt_facility_initialize() since this leads to unreachable code in bsp_interrupt_initialize(). Use RTEMS_DEBUG assertions in bsp_interrupt_facility_initialize() if necessary.
* bsps/irq: bsp_interrupt_vector_disable()Sebastian Huber2021-07-261-1/+2
| | | | | | Return a status code for bsp_interrupt_vector_disable(). Update #3269.
* bsps/irq: bsp_interrupt_vector_enable()Sebastian Huber2021-07-261-1/+2
| | | | | | Return a status code for bsp_interrupt_vector_enable(). Update #3269.
* bsps/irq: Add rtems_interrupt_is_pending()Sebastian Huber2021-07-261-0/+11
| | | | | | Add a default implementation which just returns RTEMS_UNSATISFIED. Update #3269.
* bsps/irq: Add rtems_interrupt_get_attributes()Sebastian Huber2021-07-261-0/+8
| | | | | | | Add a default implementation which clears the attributes to zero and just returns RTEMS_SUCCESSFUL for valid parameters. Update #3269.
* bsps/irq: Add rtems_interrupt_raise()Sebastian Huber2021-07-261-0/+12
| | | | | | | | | Add rtems_interrupt_raise_on() and rtems_interrupt_clear(). Add a default implementation which just returns RTEMS_UNSATISFIED for valid parameters. Update #3269.
* bsps/irq: Add rtems_interrupt_vector_is_enabled()Sebastian Huber2021-07-261-0/+11
* Fixes for TMS570 BSPRobin Mueller2021-07-201-3/+3
| | | | | | | | | When compiling the lwIP port for the TMS570, there were issues with the BSP. Headers are expected in a folder named ti_herc which did not exist. This fixes the issue. Furthermore, there were multiple warnings about define redefinitions. This was fixed as well.
* bsps/irq: Remove BSP_INTERRUPT_VECTOR_MAXSebastian Huber2021-06-241-1/+0
| | | | | | This define is no longer used. Update #3269.
* bsps/irq: Use BSP_INTERRUPT_VECTOR_COUNTSebastian Huber2021-06-241-1/+1
| | | | | | Use BSP_INTERRUPT_VECTOR_COUNT instead of BSP_INTERRUPT_VECTOR_MAX. Update #3269.
* bsps/irq: Add BSP_INTERRUPT_VECTOR_COUNTSebastian Huber2021-06-241-0/+1
| | | | | | | | | | | | | Assert BSP_INTERRUPT_VECTOR_MAX + 1 == BSP_INTERRUPT_VECTOR_COUNT. After building all BSPs with this patch, BSP_INTERRUPT_VECTOR_MAX can be removed and replaced by BSP_INTERRUPT_VECTOR_COUNT. The BSP_INTERRUPT_VECTOR_COUNT allows a default implementation which supports no interrupt vector at all. Using COUNT instead of MAX may avoid some interpretation issues, for example is the maximum value a valid vector number or not. Update #3269.
* bsps/irq: Remove BSP_INTERRUPT_VECTOR_MINSebastian Huber2021-06-241-1/+0
| | | | | | | | | | Remove BSP_INTERRUPT_VECTOR_MIN and unconditionally let interrupt vector numbers start with zero. The BSP_INTERRUPT_VECTOR_MIN == 0 invariant was tested by the previous commit and building all BSPs. Update #3269.
* bsps: Replace bsp_specs with an empty fileSebastian Huber2021-01-281-9/+0
| | | | | | | This fixes an issue with the latest tool chain which adds the default linker script in the endfile specification. Update #3250.
* bsps: Remove unused bsp_stack_main_sizeSebastian Huber2020-12-034-12/+0
* Use RTEMS_SYSINIT_ORDER_LAST_BUT_5Sebastian Huber2020-02-041-1/+1
| | | | | | | | Use RTEMS_SYSINIT_ORDER_LAST_BUT_5 instead of RTEMS_SYSINIT_ORDER_LAST to allow applications and support functions to place system initialization handlers behind the standard handlers. Update #3838.
* tms570ls3137_hdk_with_loader-testsuite.tcfg: Update to account for static ↵Joel Sherrill2019-03-121-0/+2
| | | | allocation and BSP small memory
* tms570ls3137_hdk_intram-testsuite.tcfg: Update to account for static ↵Joel Sherrill2019-03-121-0/+2
* tms570ls3137_hdk-testsuite.tcfg: Update to account for static allocation and ↵Joel Sherrill2019-03-121-0/+2
| | | | BSP small memory
* bsps: Adjust bsp.h Doxygen groupsSebastian Huber2019-03-0833-34/+46
| | | | Update #3706.
* Remove explicit file names from @fileSebastian Huber2019-02-2833-33/+33
| | | | | | This makes the @file documentation independent of the actual file name. Update #3707.
* bsp/tms570: correct baudrate calculation.Pavel Pisa2018-11-141-1/+1
* bsp/tms570: correct inclusion of header files for build with HW init.Pavel Pisa2018-11-1412-21/+21
| | | | The build fails when TMS570_USE_HWINIT_STARTUP=1 option is set.
* bsp/tms570: Simple fix to resolve macro redefinitions.Pavel Pisa2018-10-151-34/+46
| | | | closes #3347
* Remove Clock_driver_support_shutdown_hardware()Sebastian Huber2018-06-271-16/+0
| | | | | | | | | | | | | | | | | The aim of this clock driver hook was to stop clock tick interrupts at some late point in the exit() procedure. The use of atexit() pulls in malloc() which pulls in errno. It is incompatible with the intention of the CONFIGURE_DISABLE_NEWLIB_REENTRANCY configuration option. The exit() function must be called from thread context, so accompanied clock tick interrupts should cause no harm. On the contrary, someone may assume a normal operating system operation, e.g. working timeouts. Remove the Clock_driver_support_shutdown_hardware() clock driver hook. Close #3436.
* Add _CPU_Counter_frequency()Sebastian Huber2018-06-151-2/+5
| | | | | | | | | | Add rtems_counter_frequency() API function. Use it to initialize the counter value converter via the new system initialization step (RTEMS_SYSINIT_CPU_COUNTER). This decouples the counter implementation and the counter converter. It avoids an unnecessary pull in of the 64-bit integer division from libgcc. Update #3456.
* bsps: Move documentation, etc. files to bspsSebastian Huber2018-04-261-0/+148
| | | | | | This patch is a part of the BSP source reorganization. Update #3285.
* bsp/tms570: Move cpucounterread.c to bspsSebastian Huber2018-04-251-0/+62
* bsps: Move interrupt controller support to bspsSebastian Huber2018-04-231-0/+202
* bsp/tms570: Move more start to bspsSebastian Huber2018-04-2315-0/+3495
* bsps: Move make/custom/* files to bspsSebastian Huber2018-04-238-0/+85
| | | | | | | | | Adjust various build files. Remove automatic generation of the c/src/lib/libbsp/*/acinclude.m4 files from bootstrap script. This patch is a part of the BSP source reorganization. Update #3285.
* bsps: Move startup files to bspsSebastian Huber2018-04-208-0/+301
| | | | | | | | Adjust build support files to new directory layout. This patch is a part of the BSP source reorganization. Update #3285.
* bsps: Move console drivers to bspsSebastian Huber2018-04-202-0/+768
* bsps: Move clock drivers to bspsSebastian Huber2018-04-201-0/+190
* Remove make preinstallChris Johns2018-01-2554-0/+16756
