This option replaces BSP_OSCILATOR_CLOCK. It may be used in PLL setup
calculatios.
Update #4982.
Update #4982.
Update #4982.
Update #4982.
Update #4982.
Update #4982.
Update #4982.
Update #4982.
Update #4982.
Update #4982.
Update #4982.
Update #4982.
Remove obsolete tms570ls3137_hdk_with_loader BSP variant. With the new
memory origin/size build options this variant is no longer required.
Update #4982.
Update #4982.
Update #4982.
Rename tms570_initialize_and_clear() in
tms570_pom_initialize_and_clear().
Update #4982.
Update #4982.
Change license to BSD-2-Clause according to file history and contributor
agreements. Add Doxygen file comments.
Update #3053.
Update #3707.
Update #4982.
Update #4982.
Update #4982.
Update #4982.
Replace TMS570_MMR_SELECT_GMII_SEL with TMS570_MMR_SELECT_MII_MODE and
TMS570_MMR_SELECT_RMII_MODE.
Rearrange pin function bit fields to allow the clearing of all function
bits through TMS570_PIN_AND_FNC().
Move implementation details to source file.
brains GmbH.
This avoids multiple definition errors.
When compiling the lwIP port for the TMS570, there
were issues with the BSP. Headers are expected in a folder
named ti_herc which did not exist. This fixes the issue.
Furthermore, there were multiple warnings about define redefinitions.
This was fixed as well.
This define is no longer used.
Update #3269.
Assert BSP_INTERRUPT_VECTOR_MAX + 1 == BSP_INTERRUPT_VECTOR_COUNT.
After building all BSPs with this patch, BSP_INTERRUPT_VECTOR_MAX can be
removed and replaced by BSP_INTERRUPT_VECTOR_COUNT. The
BSP_INTERRUPT_VECTOR_COUNT allows a default implementation which supports no
interrupt vector at all. Using COUNT instead of MAX may avoid some
interpretation issues, for example is the maximum value a valid vector number
or not.
Update #3269.
Remove BSP_INTERRUPT_VECTOR_MIN and unconditionally let interrupt vector
numbers start with zero.
The BSP_INTERRUPT_VECTOR_MIN == 0 invariant was tested by the previous commit
and building all BSPs.
Update #3269.
Update #3706.
This makes the @file documentation independent of the actual file name.
Update #3707.
closes #3347
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
