path: root/bsps/arm/tms570/include/bsp/ti_herc/reg_dma.h (unfollow)
2024-01-15bsp/tms570: Relicense to BSD-2-ClauseSebastian Huber1-0/+10
Change license to BSD-2-Clause according to file history and contributor agreements. Add Doxygen file comments. Update #3053. Update #3707. Update #4982.
2018-01-25Remove make preinstallChris Johns1-0/+0
2015-07-20bsp/tms570: skipped 32bit field definitions and corrected single bit fieldsPremysl Houdek1-118/+97
there is no need to define access macros for field covering whole registers. In addition, BSP_FLD32 does not work right for field 32bit length. Signed-off-by: Premysl Houdek <kom541000@gmail.com>
2015-07-16bsp/tms570: New/generated header files for TMS570 SoC peripherals registers.Premysl Houdek1-0/+732
The header files are generated by script make_header.py. Current script's version can be found at: https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python Registers offsets and fields have been extracted from reference manual. Signed-off-by: Premysl Houdek <kom541000@gmail.com>
