* | arm/stm32h7: Add STM32H7_USART3_GPIO_* | Sebastian Huber | 2021-04-06 | 1 | -2/+4 | |
* | arm/stm32h7: Add STM32H7_HSE_FREQUENCY | Sebastian Huber | 2021-04-06 | 1 | -0/+5 | |
* | stm32h7: Add init for sdmmc pins | Christian Mauderer | 2021-04-01 | 2 | -0/+90 | |
| | | | | Update #4372 | |||||
* | stm32h7: Add SDMMC modules to clock | Christian Mauderer | 2021-04-01 | 2 | -3/+15 | |
* | bsps: Replace bsp_specs with an empty file | Sebastian Huber | 2021-01-28 | 1 | -9/+0 | |
| | | | | | | | This fixes an issue with the latest tool chain which adds the default linker script in the endfile specification. Update #3250. | |||||
* | bsp/stm32h7: Split console configuration | Sebastian Huber | 2021-01-04 | 21 | -150/+498 | |
| | | | | | | | This allows applications to individually provide configuration structures. Update #4209. | |||||
* | bsp/stm32h7: Split start configuration | Sebastian Huber | 2021-01-04 | 5 | -38/+166 | |
* | bsp/stm32h7: Add and use BSP Doxygen group | Sebastian Huber | 2020-11-26 | 216 | -0/+3517 | |
| | | | | Update #3910. | |||||
* | cpu/armv7m: Add table based init for ARMV7M_MPU | Christian Mauderer | 2020-11-20 | 3 | -118/+121 | |
| | | | | | | | Modify the MPU functions of the stm32h7 BSP to be table based and available for all ARMV7M BSPs. Update #4180 | |||||
* | bsp/stm32h7: New BSP | Sebastian Huber | 2020-10-27 | 31 | -0/+3670 | |
* | bsp/stm32h7: Fix warnings | Sebastian Huber | 2020-10-27 | 2 | -15/+15 | |
* | bsp/stm32h7: Disable unused functions | Sebastian Huber | 2020-10-27 | 5 | -0/+28 | |
* | bsp/stm32h7: Enable LL drivers | Sebastian Huber | 2020-10-27 | 46 | -88/+88 | |
* | bsp/stm32h7: Move <math.h> include | Sebastian Huber | 2020-10-27 | 3 | -1/+2 | |
| | | | | | | This is necessary for libbsd compatibility. Update #3910. | |||||
* | bsp/stm32h7: Constify some functions | Sebastian Huber | 2020-10-27 | 6 | -12/+12 | |
* | bsp/stm32h7: Import from STM32CubeMX-5.6.0 | Sebastian Huber | 2020-10-27 | 259 | -0/+706411 | |
Update #3910. |
