Nucleo board does not provide any external memory so code does not have
any function here anyway.
Sponsored-By: Precidata
The idea here is to prepare for better per-board specialization
of the hooks function code.
Besides C files for the BSP variant the patch also provides license
clarification on system_stm32h7xx.c file which is provided
in boards/stm/stm32h747i-disco directory.
The files comes from STM32CubeH7 project and references "root directory"
in its license comment and it's not clear where this points out.
Let's add clarification comment about it and also based on it
and resulting license let's add SPDX license identifier.
in boards/stm/stm32h757i-eval directory.
The files are already presented in boards directories and are not needed
in start directory anymore.
Also adjust BSP spec file to make it buildable with board files.
Updated content comes from STM32CubeIDE 1.9.0 generated for STM32H7B3I-DK
board and have RTEMS related changes merged in.
The patch merges differences in FMC configuration between system_stm32h7xx.c
file generated by STM32CubeIDE for 743i-eval2 board and the current RTEMS
ext-mem-ctl.c file.
STM32H7B3I-DK BSP variant
The changes provided here are a result of a merge from various examples
system_stm32h7xx.c files provided by STMicroelectronics for the STM32H7B3I-DK
board with the original RTEMS file provided for the STM32H743I-EVAL2 board.
while compiling for STM32H7B3I-DK BSP
STM32H7B3I-DK BSP)
STM32H7B3I-DK BSP)
Note: the ethernet port is not presented on the board anyway.
function
Updates #3937.
These patches were submitted a few months ago, but it was found out
that the default-by-family: [] were missing in the GPIO .yml lines.
This was fixed in this patch.
This patch accounts for different pins for the ETH peripheral
on STM32H7 devices. For example, the Nucleo H743ZI has slightly
different pins than other STM32H7 boards.
This define is no longer used.
Update #3269.
Assert BSP_INTERRUPT_VECTOR_MAX + 1 == BSP_INTERRUPT_VECTOR_COUNT.
After building all BSPs with this patch, BSP_INTERRUPT_VECTOR_MAX can be
removed and replaced by BSP_INTERRUPT_VECTOR_COUNT. The
BSP_INTERRUPT_VECTOR_COUNT allows a default implementation which supports no
interrupt vector at all. Using COUNT instead of MAX may avoid some
interpretation issues, for example is the maximum value a valid vector number
or not.
Update #3269.
Remove BSP_INTERRUPT_VECTOR_MIN and unconditionally let interrupt vector
numbers start with zero.
The BSP_INTERRUPT_VECTOR_MIN == 0 invariant was tested by the previous commit
and building all BSPs.
Update #3269.
Uses configured millisecond per ticks
This now uses rtems_clock_get_uptime_nanoseconds
to calculate the uptime ticks in milliseconds.
Update #4372
Update #4372
This fixes an issue with the latest tool chain which adds the default
linker script in the endfile specification.
Update #3250.
This allows applications to individually provide configuration
structures.
Update #4209.
structures.
Update #4209.
Update #3910.
Modify the MPU functions of the stm32h7 BSP to be table based and
available for all ARMV7M BSPs.
Update #4180
Update #3910.
Update #3910.
Update #3910.
Update #3910.
This is necessary for libbsd compatibility.
Update #3910.
Update #3910.
Update #3910.
