This adds support for the STM32H750B-DK discovery kit. This kit includes
a built-in STLINKv3 debugger which provides a USB serial bridge for
USART3. USART1 is routed to the Arduino header and USART2 is routed to
the STMOD connector. This BSP reuses what would otherwise be duplicated
files from the stm32h747i-disco BSP. Note that system_stm32h7xx.c has
been imported from the STM repository with two minor changes wrapped
with #if __rtems__. This hardware has been tested with hello and ticker.
brains GmbH.
This allows applications to individually provide configuration
structures.
Update #4209.
structures.
Update #4209.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Update #3904.
Remove all comments and copyrightable content from the moved content.
Use BSD-2-Clause license for new file.
Move the default configuration to library files so that application
configurations do not include the definitions for the default case.
Update #3053.
Update #3875.
Move the unified workspace configuration constant out of the
configuration table.
Provide a default definition of the unified workspace constant.
Update #3875.
With the removal of the CONFIGURE_HAS_OWN_INIT_TASK_TABLE configuration
option at most one Classic API user initialization task can be
configured.
Provide an RTEMS API configuration table for backward compatibility.
Update #3873.
Use a dedicate system initialization step to zero the memory used for
the workspace and C program heap.
This avoids dead code in case CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY is
not configured.
GCI Username: deuteriumoxide
