Add default implementations for bsp_interrupt_get_affinity() and
bsp_interrupt_set_affinity() which are required to link all tests in SMP
configurations.
Update #3269.
This define is no longer used.
Update #3269.
Assert BSP_INTERRUPT_VECTOR_MAX + 1 == BSP_INTERRUPT_VECTOR_COUNT.
After building all BSPs with this patch, BSP_INTERRUPT_VECTOR_MAX can be
removed and replaced by BSP_INTERRUPT_VECTOR_COUNT. The
BSP_INTERRUPT_VECTOR_COUNT allows a default implementation which supports no
interrupt vector at all. Using COUNT instead of MAX may avoid some
interpretation issues, for example is the maximum value a valid vector number
or not.
Update #3269.
Remove BSP_INTERRUPT_VECTOR_MIN and unconditionally let interrupt vector
numbers start with zero.
The BSP_INTERRUPT_VECTOR_MIN == 0 invariant was tested by the previous commit
and building all BSPs.
Update #3269.
Fixes #3903
This patch adds driver for Mini UART present in Raspberry Pi 3
and above, this UART is currently used as the primary UART in
these models.
The Mini UART is similar to ns16550, this driver is built
upon libchip/ns16550.
Replaces the legacy termios API with new termios API (#3034)
Replaces the custom PL011 serial driver with RTEMS arm-pl011.
Update #3034
This commit adds FDT support to the BSP.
The BSP tried to get the size of the SDRAM based on the revision code.
Unfortunately the code had some bugs so that the default size has been
used. Beneath that the MMU table hasn't been adapted.
This patch queries the SDRAM size via a special VC Mailbox call instead.
For the MMU adaption a simmilar method to the one in the imx BSP is
used.
Update #3706.
replace.
searching and sorting.
Update #3706.
This makes the @file documentation independent of the actual file name.
Update #3707.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
