* | bsps: Adjust bsp.h Doxygen groups | Sebastian Huber | 2019-03-08 | 1 | -1/+1 |
| | | | | Update #3706. | ||||
* | Add _CPU_Counter_frequency() | Sebastian Huber | 2018-06-15 | 1 | -1/+5 |
| | | | | | | | | | | Add rtems_counter_frequency() API function. Use it to initialize the counter value converter via the new system initialization step (RTEMS_SYSINIT_CPU_COUNTER). This decouples the counter implementation and the counter converter. It avoids an unnecessary pull in of the 64-bit integer division from libgcc. Update #3456. | ||||
* | bsps: Move startup files to bsps | Sebastian Huber | 2018-04-20 | 1 | -0/+38 |
Adjust build support files to new directory layout. This patch is a part of the BSP source reorganization. Update #3285. |
