brains GmbH.
Updates #3053.
Updates #4625.
Update #3706.
Update #3285.
This patch refactors a lot of the existing doxygen within libbsp/arm/lpc32xx.
Much of this refactoring was just renaming of existing groups to conform to a
more consistent naming structure. With the addition of a doxygen header for
tm27.h, all files within lpc32xx belong to doxygen group now. lpc32xx should
be used a reference for adding doxygen to other bsps.
Use mpc55xx_wait_for_interrupt().
Rework of the start sequence to reduce the amount assembler code and to
support configuration tables which may be provided by the application.
* make/custom/mpc5566evb_spe.cfg, make/custom/mpc5674fevb_spe.cfg,
startup/linkcmds.mpc5566evb_spe, startup/linkcmds.mpc5674fevb_spe,
startup/reset.c: New files.
* Makefile.am, preinstall.am: Reflect changes above.
* startup/early-init.c: Added missing section attribute.
* configure.ac, network/smsc9218i.c: New BSP options
SMSC9218I_EDMA_RX_CHANNEL and SMSC9218I_EDMA_TX_CHANNEL. Enable reset
at cleanup.
PR 1799/bsps
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.ac,
clock/clock-config.c, console/console-config.c,
console/uart-bridge-master.c, console/uart-bridge-slave.c,
include/.cvsignore, include/bsp.h, include/hwreg_vals.h,
include/intercom.h, include/irq.h, include/mmu.h, include/qoriq.h,
include/tm27.h, include/tsec-config.h, include/u-boot-config.h,
include/uart-bridge.h, irq/irq.c, make/custom/qoriq.inc,
make/custom/qoriq_core_0.cfg, make/custom/qoriq_core_1.cfg,
make/custom/qoriq_p1020rdb.cfg, network/if_intercom.c,
network/network.c, rtc/rtc-config.c, shmsupp/intercom-mpci.c,
shmsupp/intercom.c, shmsupp/lock.S, start/start.S,
startup/bsppredriverhook.c, startup/bspreset.c, startup/bspstart.c,
startup/linkcmds.base, startup/linkcmds.qoriq_core_0,
startup/linkcmds.qoriq_core_1, startup/linkcmds.qoriq_p1020rdb,
startup/mmu-config.c, startup/mmu-tlb1.S, startup/mmu.c: New files.
* include/u-boot.h: Removed file.
* include/u-boot-config.h: New file.
* include/bsp.h, start/start.S, startup/bspstart.c: Use new U-Boot
support.
* preinstall.am, shared/lpc/include/lpc-i2s.h,
shared/startup/linkcmds.armv4, shared/startup/linkcmds.armv7: New
files.
* Makefile.am: Added header and linker command files intended to be
used by every ARM BSP.
* shared/startup/linkcmds.base: Support for EABI and ARM ELF standard.
* shared/include/linker-symbols.h: Update due to linker command file
changes.
* shared/start/start.S, shared/include/start.h: Renamed entry symbol
from start to _start to avoid namespace conflicts. Update due to
linker command file changes.
