path: root/bsps/arm/lpc32xx/include/bsp/lpc32xx.h (follow)
* bsps/arm/: Scripted embedded brains header file clean upJoel Sherrill2022-03-101-6/+1
| | | | Updates #4625.
* bsps: Adjust bsp.h Doxygen groupsSebastian Huber2019-03-081-1/+1
| | | | Update #3706.
* Remove make preinstallChris Johns2018-01-251-0/+641
