path: root/bsps/arm/lpc24xx (unfollow)
2018-04-23bsps: Move make/custom/* files to bspsSebastian Huber24-0/+253
Adjust various build files. Remove automatic generation of the c/src/lib/libbsp/*/acinclude.m4 files from bootstrap script. This patch is a part of the BSP source reorganization. Update #3285.
2018-04-20bsps: Move startup files to bspsSebastian Huber23-0/+1963
Adjust build support files to new directory layout. This patch is a part of the BSP source reorganization. Update #3285.
2018-04-20bsps: Move console drivers to bspsSebastian Huber4-0/+254
2018-01-25Remove make preinstallChris Johns15-0/+4550
