2023-05-20 | Update company name | Sebastian Huber | 1 | -1/+1 | |
The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | |||||
2022-07-08 | bsps/arm/lpc24xx: Change license to BSD-2 | Joel Sherrill | 1 | -3/+22 | |
Updates #3053. | |||||
2022-03-10 | bsps/arm/: Scripted embedded brains header file clean up | Joel Sherrill | 1 | -6/+0 | |
Updates #4625. | |||||
2018-08-20 | bsps/arm: Fix PL111 register define re-definition | Sebastian Huber | 1 | -1/+1 | |
Close #3502. | |||||
2018-04-20 | bsps: Move startup files to bsps | Sebastian Huber | 1 | -0/+0 | |
Adjust build support files to new directory layout. This patch is a part of the BSP source reorganization. Update #3285. | |||||
2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | 1 | -1/+1 | |
2014-02-19 | score: Add RTEMS_FATAL_SOURCE_BSP | Sebastian Huber | 1 | -13/+5 | |
Merge RTEMS_FATAL_SOURCE_BSP_GENERIC and RTEMS_FATAL_SOURCE_BSP_SPECIFIC into new fatal source RTEMS_FATAL_SOURCE_BSP. This makes it easier to figure out the code position given a fatal source and code. | |||||
2014-01-30 | bsp/lpc24xx: Fix compile error | Sebastian Huber | 1 | -1/+1 | |
2014-01-10 | bsp/lpc24xx: Add PL111 support | Sebastian Huber | 1 | -0/+141 | |
