path: root/bsps/arm/lpc24xx/include/bsp (follow)
* bsps/irq: Remove BSP_INTERRUPT_VECTOR_MINSebastian Huber2021-06-241-2/+0
| | | | | | | | | | Remove BSP_INTERRUPT_VECTOR_MIN and unconditionally let interrupt vector numbers start with zero. The BSP_INTERRUPT_VECTOR_MIN == 0 invariant was tested by the previous commit and building all BSPs. Update #3269.
* bsp/lpc24xx: Fix LPC24XX_IO_PORT_COUNTSebastian Huber2019-06-041-1/+5
* bsp/lpc24xx: Use fast slew rate for EMC pinsSebastian Huber2019-05-091-84/+63
* bsp/lpc24xx: Add LPC17XX_PIN_TYPE_FAST_SLEW_RATESebastian Huber2019-05-091-1/+2
* bsp/lpc24xx: Convert I2C driver to Linux APISebastian Huber2019-03-151-35/+31
| | | | | | Change license to BSD-2-Clause. Close #3725.
* bsp/lpc24xx: Convert SSP driver to Linux APISebastian Huber2019-03-121-17/+37
| | | | | | | Use interrupts instead of polled or DMA driven mode. Change license to BSD-2-Clause. Close #3724.
* bsp/lpc24xx: Add alternative SSP2 pinsSebastian Huber2019-03-121-0/+8
* bsps: Adjust bsp.h Doxygen groupsSebastian Huber2019-03-0811-18/+18
| | | | Update #3706.
* Remove make preinstallChris Johns2018-01-2512-0/+4400
