path: root/bsps/arm/lpc24xx/include/bsp (follow)
* bsp/lpc24xx: Add LPC17XX_PIN_TYPE_FAST_SLEW_RATESebastian Huber2019-05-091-1/+2
* bsp/lpc24xx: Convert I2C driver to Linux APISebastian Huber2019-03-151-35/+31
| | | | | | Change license to BSD-2-Clause. Close #3725.
* bsp/lpc24xx: Convert SSP driver to Linux APISebastian Huber2019-03-121-17/+37
| | | | | | | Use interrupts instead of polled or DMA driven mode. Change license to BSD-2-Clause. Close #3724.
* bsp/lpc24xx: Add alternative SSP2 pinsSebastian Huber2019-03-121-0/+8
* bsps: Adjust bsp.h Doxygen groupsSebastian Huber2019-03-0811-18/+18
| | | | Update #3706.
* Remove make preinstallChris Johns2018-01-2512-0/+4400
