path: root/bsps/arm/lpc24xx/include/bsp/ssp.h (unfollow)
2019-03-12bsp/lpc24xx: Convert SSP driver to Linux APISebastian Huber1-17/+37
Use interrupts instead of polled or DMA driven mode. Change license to BSD-2-Clause. Close #3724.
2019-03-08bsps: Adjust bsp.h Doxygen groupsSebastian Huber1-2/+2
Update #3706.
2018-01-25Remove make preinstallChris Johns1-0/+0
2014-03-21Change all references of rtems.com to rtems.org.Chris Johns1-1/+1
2012-10-11Use proper 3 line form of license textJoel Sherrill1-2/+3
2009-09-18Changes throughout.Thomas Doerfler1-1/+9
2008-09-30added SSP support files, fixed some typosThomas Doerfler1-11/+7
2008-09-22lpc24xx: new BSPThomas Doerfler1-19/+7
2008-08-202008-08-20 Sebastian Huber <sebastian.huber@embedded-brains.de>Joel Sherrill1-1/+1
* include/mpc55xxevb.h, network/network.c, startup/sd-card-init.c, tests/tests.c: Added copyright information. Added missing prototypes. Fixed integer conversion warning. * startup/bspclean.c: Include bootcard.h.
2008-07-14updated gen83xx BSPThomas Doerfler1-0/+54
updated haleakala BSP added MPC55xx BSP
