path: root/bsps/arm/lpc24xx/include/bsp/lpc-clock-config.h (unfollow)
2019-03-08bsps: Adjust bsp.h Doxygen groupsSebastian Huber1-1/+1
Update #3706.
2018-01-25Remove make preinstallChris Johns1-0/+0
2015-05-20bsps: Convert clock drivers to use a timecounterAlexander Krutwig1-0/+2
Update #2271.
2014-03-21Change all references of rtems.com to rtems.org.Chris Johns1-1/+1
2011-11-082011-11-08 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber1-2/+2
* include/lpc17xx.h: New file. * Makefile.am, preinstall.am: Reflect change above. Update due to API changes. * configure.ac, console/console-config.c, include/bsp.h, include/io.h, include/irq.h, include/lcd.h, include/lpc-clock-config.h, include/lpc24xx.h, include/start-config.h, irq/irq-dispatch.c, irq/irq.c, misc/bspidle.c, misc/io.c, misc/lcd.c, misc/restart.c, misc/system-clocks.c, ssp/ssp.c, startup/bspreset.c, startup/bspstart.c, startup/bspstarthooks.c, startup/start-config-emc-dynamic.c, startup/start-config-emc-static.c, startup/start-config-pinsel.c: Basic support for LPC17XX. New memory configurations for W9825G2JB75I, IS42S32800B, and SST39VF3201.
2009-12-16add missing filesThomas Doerfler1-9/+11
2009-12-15add support for LPC32xxThomas Doerfler1-0/+45
