brains GmbH.
Change license to BSD-2-Clause.
Close #3725.
Update #3706.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
* i2c/i2c-config.c: New file.
* include/lcd.h: Removed EMC definitions.
* misc/dma.c: Fixed initialization.
* include/i2c.h, include/io.h, include/lpc-ethernet-config.h,
include/lpc24xx.h, console/console-config.c, i2c/i2c.c, misc/io.c,
misc/lcd.c, startup/bspstart.c, startup/bspstarthooks.c: New pin
configuration API.
* Makefile.am, preinstall.am: Update.
