2023-05-20 | Update company name | Sebastian Huber | 1 | -1/+1 | |
The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | |||||
2022-07-08 | bsps/arm/lpc24xx: Change license to BSD-2 | Joel Sherrill | 1 | -3/+22 | |
Updates #3053. | |||||
2022-03-10 | bsps/arm/: Scripted embedded brains header file clean up | Joel Sherrill | 1 | -6/+0 | |
Updates #4625. | |||||
2019-03-08 | bsps: Adjust bsp.h Doxygen groups | Sebastian Huber | 1 | -1/+1 | |
Update #3706. | |||||
2018-04-20 | bsps: Move console drivers to bsps | Sebastian Huber | 1 | -0/+0 | |
This patch is a part of the BSP source reorganization. Update #3285. | |||||
2014-10-07 | libchip/serial: Add alternative NS16550 driver | Sebastian Huber | 1 | -4/+6 | |
Use the Termios device API. | |||||
2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | 1 | -1/+1 | |
2013-02-11 | bsp/lpc24xx: Move UART probes to separate files | Sebastian Huber | 1 | -0/+38 | |
