Updates #3053.
Updates #4625.
This define is no longer used.
Update #3269.
Assert BSP_INTERRUPT_VECTOR_MAX + 1 == BSP_INTERRUPT_VECTOR_COUNT.
After building all BSPs with this patch, BSP_INTERRUPT_VECTOR_MAX can be
removed and replaced by BSP_INTERRUPT_VECTOR_COUNT. The
BSP_INTERRUPT_VECTOR_COUNT allows a default implementation which supports no
interrupt vector at all. Using COUNT instead of MAX may avoid some
interpretation issues, for example is the maximum value a valid vector number
or not.
Update #3269.
Remove BSP_INTERRUPT_VECTOR_MIN and unconditionally let interrupt vector
numbers start with zero.
The BSP_INTERRUPT_VECTOR_MIN == 0 invariant was tested by the previous commit
and building all BSPs.
Update #3269.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
