line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
* 0001-Fixed-interrupt-handling-for-ARMv7M.patch,
0002-Fixed-system-handler-priority-register-access.patch,
0003-Disable-priority_mask-unused-for-NVIC.patch, 0004-Typo.patch,
0005-Evil-hack-for-BASEPRI-BASEPRI_MAX.patch,
0006-Evil-hack-to-increase-the-RAM-size.patch, bsp_specs, ChangeLog,
clock/clock-config.c, configure.ac, console/console-config.c,
console/uart.c, .cvsignore, include/bsp.h, include/.cvsignore,
include/irq.h, include/lm3s69xx.h, include/uart.h, irq/irq.c,
make/custom/lm3s6965.cfg, make/custom/lm3s69xx.inc, Makefile.am,
README, start/start.S, startup/bspreset.c, startup/bspstart.c,
startup/bspstarthook.c, startup/linkcmds.lm3s6965, timer/timer.c: New
files.
