path: root/bsps/arm/include (follow)
* arm: Simplify CPU counter supportSebastian Huber2018-06-151-0/+78
| | | | | | | | | | Use the standard ARMv7-M systick module for the ARMv7-M CPU counter instead of DWT counter since the DWT counter is affected by power saving states. Use an inline function for _CPU_Counter_difference() for all ARM BSPs. Update #3456.
* Add _CPU_Counter_frequency()Sebastian Huber2018-06-151-9/+0
| | | | | | | | | | Add rtems_counter_frequency() API function. Use it to initialize the counter value converter via the new system initialization step (RTEMS_SYSINIT_CPU_COUNTER). This decouples the counter implementation and the counter converter. It avoids an unnecessary pull in of the 64-bit integer division from libgcc. Update #3456.
* bsp/arm-a8core-start.h: Add void return type to fix warningJoel Sherrill2018-03-161-2/+2
* Remove make preinstallChris Johns2018-01-2536-0/+8729
