This driver will be shared with the xilinx-zynqmp BSP.
Update #3682.
This variable is BSP specific and should be removed from the driver
header file.
Update #3682.
Relicense contributions from Chris Johns, Christian Mauderer,
embedded brains GmbH, Joel Sherrill, OAR, Pavel Pisa, Ralf Kirchner, and
Sebastian Huber.
Update #3053.
Update #3706.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
* configure.ac, console/console-config.c, i2c/i2c_init.c,
include/bsp.h, include/hwreg_vals.h, include/irq.h, include/tm27.h,
include/tsec-config.h, irq/irq.c, network/network.c, spi/spi_init.c,
startup/bspstart.c: Address some of the issues spotted by the
check_bsp script.
* include/u-boot.h: Removed file.
* include/u-boot-config.h, include/tsec-config.h: New files.
* include/bsp.h, start/start.S, startup/bspstart.c: Use new U-Boot
support.
* network/network.c: Update for API changes.
* Makefile.am, preinstall.am: Reflect changes above.
* shared/bspgetworkarea.c: Include <bsp/u-boot.h> if necessary.
* shared/include/u-boot.h, shared/src/bsp-uboot-board-info.c: New
files.
