path: root/bsps/arm/include/bsp/lpc-emc.h (follow)
* bsps/arm/include: Change license to BSD-2Joel Sherrill2022-07-081-3/+22
| | | | Updates #3053.
* bsps/arm/: Scripted embedded brains header file clean upJoel Sherrill2022-03-101-6/+0
| | | | Updates #4625.
* bsps: Adjust bsp.h Doxygen groupsSebastian Huber2019-03-081-2/+2
| | | | Update #3706.
* Remove make preinstallChris Johns2018-01-251-0/+170
