path: root/bsps/arm/include/bsp/arm-gic-regs.h (unfollow)
2020-10-05bsps: Break out AArch32 GICv3 supportKinsey Moore1-217/+0
This breaks out AArch32-specific code so that the shared GICv3 code can be reused by other architectures.
2020-01-17bsps/arm/shared: Add GICv3 implementationKinsey Moore1-1/+75
This adds support for the GICv3 interrupt controller along with the redistributor to control SGIs and PPIs which wasn't present in GICv2 implementations. GICv3 implementations only optionally support memory-mapped GICC interface interaction and require system register access be implemented, so the GICC interface is accessed only through system registers.
2019-02-28bsps/arm: Fix typoSebastian Huber1-1/+1
2019-02-28bsps/arm: Support GIC group 0/1Sebastian Huber1-2/+7
2018-01-25Remove make preinstallChris Johns1-0/+0
2014-03-21Change all references of rtems.com to rtems.org.Chris Johns1-1/+1
2013-12-22libbsp/arm: add doxygen to arm shared headersSzkocsovszki Zsolt1-0/+8
2013-05-03bsp/realview-pbx-a9: New BSPSebastian Huber1-0/+130
