Updates #3053.
Updates #4625.
Make sure the branch predictors are invalidated before the first branch
is executed.
Update #4202.
Set the VBAR to the vector table in the start section before
bsp_start_hook_0() is called to earlier handle exceptions in RTEMS.
Set the VBAR to the normal vector table in start.S for the main
processor. Secondary processors set it in bsp_start_hook_0().
Update #4202.
Add a workaround for Cortex-A9 Errata 845369: A short loop including a DMB
instruction might cause a denial of service on another which executes a CP15
broadcast operation.
Close #4115.
Add a workaround for Cortex-A9 Errata 845369: Under Very Rare Timing
Circumstances Transition into Streaming Mode Might Create Data Corruption.
Update #4115.
This breaks out AArch32-specific code so that the shared GICv3 code can
be reused by other architectures.
Update #3706.
Pass current processor control as first parameter to make dependency
more explicit.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
