path: root/bsps/arm/include/bsp/arm-a9mpcore-irq.h (follow)
* bsps/arm/: Scripted embedded brains header file clean upJoel Sherrill2022-03-101-6/+0
| | | | Updates #4625.
* bsps: Adjust shared Doxygen groupsSebastian Huber2019-03-081-1/+1
| | | | Update #3706.
* Remove make preinstallChris Johns2018-01-251-0/+40
