path: root/bsps/arm/include/bsp/arm-a9mpcore-clock.h (follow)
* bsps/arm/include: Change license to BSD-2Joel Sherrill2022-07-081-3/+22
| | | | Updates #3053.
* Add _CPU_Counter_frequency()Sebastian Huber2018-06-151-9/+0
| | | | | | | | | | Add rtems_counter_frequency() API function. Use it to initialize the counter value converter via the new system initialization step (RTEMS_SYSINIT_CPU_COUNTER). This decouples the counter implementation and the counter converter. It avoids an unnecessary pull in of the 64-bit integer division from libgcc. Update #3456.
* Remove make preinstallChris Johns2018-01-251-0/+38
