2023-05-22 | bsp/imxrt: Update support library from mcux-sdk | Christian Mauderer | 1 | -25/+404 | |
This imports new files from the mcux-sdk support library. NXP now offers the library as a git repository instead of a zip package. The git repository supports multiple CPUs from the i.MXRT family: https://github.com/nxp-mcuxpresso/mcux-sdk.git The imported files are from revision 2b9354539e6e4f722749e87b0bdc22966dc080d9 This revision is the same as MCUXpresso 2.13.0 with small bug fixes. For importing the files, a script has been used, that parses the mcux-sdk cmake files and creates the yaml files for RTEMS: https://raw.githubusercontent.com/c-mauderer/nxp-mcux-sdk/d21c3e61eb8602b2cf8f45fed0afa50c6aee932f/export_to_RTEMS.py | |||||
2020-11-20 | bsp/imxrt: Import files from MCUXpresso SDK V2.8.5 | Christian Mauderer | 1 | -0/+534 | |
The following files have been imported: cp ${SDK}/boards/evkbimxrt1050/project_template/clock_config.c nxp/boards/evkbimxrt1050 cp ${SDK}/boards/evkbimxrt1050/project_template/clock_config.h include/fsl_clock_config.h cp ${SDK}/boards/evkbimxrt1050/project_template/dcd.c start/flash-dcd.c cp ${SDK}/boards/evkbimxrt1050/project_template/pin_mux.c nxp/boards/evkbimxrt1050 cp ${SDK}/boards/evkbimxrt1050/project_template/pin_mux.h include/fsl_pin_mux.h cp ${SDK}/boards/evkbimxrt1050/xip/evkbimxrt1050_flexspi_nor_config.h include/fsl_flexspi_nor_config.h cp ${SDK}/devices/MIMXRT1052/MIMXRT1052.h include cp ${SDK}/devices/MIMXRT1052/MIMXRT1052_features.h include cp ${SDK}/devices/MIMXRT1052/drivers/fsl_*.c nxp/devices/MIMXRT1052/drivers cp ${SDK}/devices/MIMXRT1052/drivers/fsl_*.h include cp ${SDK}/devices/MIMXRT1052/fsl_device_registers.h include cp ${SDK}/devices/MIMXRT1052/system_MIMXRT1052.h include/ cp ${SDK}/devices/MIMXRT1052/xip/fsl_flexspi_nor_boot.c nxp/devices/MIMXRT1052/xip/fsl_flexspi_nor_boot.c cp ${SDK}/devices/MIMXRT1052/xip/fsl_flexspi_nor_boot.h include Update #4180 |
