2023-05-20 | Update company name | Sebastian Huber | 1 | -1/+1 | |
The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | |||||
2021-01-21 | bsps/imxrt: Add ioctl to LPSPI to get registers | Christian Mauderer | 1 | -16/+16 | |
This allows an application to get the registers of the LPSPI. That is usefull for applications that want to use DMA for a very specialized and highly optimized communication. Update #4180 | |||||
2020-11-20 | bsp/imxrt: Add new BSP | Christian Mauderer | 1 | -7/+12 | |
2020-11-20 | imx: Move imx_iomux to arm/shared | Christian Mauderer | 1 | -10/+14 | |
2020-07-24 | score: Add RTEMS_WEAK | Sebastian Huber | 1 | -7/+14 | |
Update #4032. | |||||
2020-04-16 | Canonicalize config.h include | Sebastian Huber | 1 | -1/+1 | |
Use the following variant which was already used by most source files: #ifdef HAVE_CONFIG_H #include "config.h" #endif | |||||
2020-03-16 | rtems: Add rtems_put_char() | Sebastian Huber | 1 | -4/+8 | |
Update #3904. | |||||
2020-02-25 | config: Add <rtems/confdefs/malloc.h> | Sebastian Huber | 1 | -2/+2 | |
Remove all comments and copyrightable content from the moved content. Use BSD-2-Clause license for new file. Move the default configuration to library files so that application configurations do not include the definitions for the default case. Update #3053. Update #3875. | |||||
2020-02-25 | config: Add _Workspace_Is_unified | Sebastian Huber | 1 | -2/+2 | |
Move the unified workspace configuration constant out of the configuration table. Provide a default definition of the unified workspace constant. Update #3875. | |||||
2020-02-25 | config: Simplify initialization task config | Sebastian Huber | 1 | -6/+3 | |
With the removal of the CONFIGURE_HAS_OWN_INIT_TASK_TABLE configuration option at most one Classic API user initialization task can be configured. Provide an RTEMS API configuration table for backward compatibility. Update #3873. | |||||
2020-02-06 | sysinit: Add RTEMS_SYSINIT_ZERO_MEMORY | Sebastian Huber | 1 | -13/+6 | |
Use a dedicate system initialization step to zero the memory used for the workspace and C program heap. This avoids dead code in case CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY is not configured. | |||||
2018-12-20 | psxhdrs: Changing copyright license to BSD-2-Clause | Jacob Shin | 1 | -11/+22 | |
2018-12-09 | psxhdrs: Add POSIX API Signature Compliance Tests for stdlib.h (GCI 2018) | Jacob Shin | 1 | -6/+4 | |
2018-12-05 | psxhdrs: Fix spacing | Joel Sherrill | 1 | -16/+16 | |
2018-12-05 | psxhdrs: POSIX API Signature Compliance Tests for assert.h (GCI 2018) | Jacob Shin | 1 | -6/+4 | |
2018-12-04 | psxhdrs: POSIX API Signature Compliance Tests for ulimit.h (GCI 2018) | Jacob Shin | 1 | -5/+6 | |
2018-12-04 | psxhdrs: Implement POSIX API Signature Compliance Tests for iconv.h (GCI 2018) | Jacob Shin | 1 | -4/+6 | |
2018-12-03 | psxhdrs: Implement POSIX API Signature Compliance Tests for fnmatch.h (GCI 2018) | Jacob Shin | 1 | -14/+7 | |
GCI Username: deuteriumoxide | |||||
2018-12-02 | psxhdrs:Add POSIX conformance test for utime.h (GCI 2018) | Shashvat Jain | 1 | -15/+17 | |
2018-11-27 | psxtests: add POSIX API signature compliance tests for dirent.h file (GCI 2018) | Himanshu40 | 1 | -0/+39 | |
