path: root/bsps/arm/imx/include/arm/freescale/imx/imx_i2creg.h (unfollow)
2023-05-20Update company nameSebastian Huber1-1/+1
The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH.
2022-07-08bsps/arm/imx: Change license to BSD-2Joel Sherrill1-3/+22
Updates #3053.
2022-03-10bsps/arm/: Scripted embedded brains header file clean upJoel Sherrill1-6/+0
Updates #4625.
2018-01-25Remove make preinstallChris Johns1-0/+0
2017-10-02bsp/imx: Fix I2C register headerSebastian Huber1-27/+31
Update #3090.
2017-09-26bsp/imx: Add register headersSebastian Huber1-0/+50
Update #3090.
