path: root/bsps/arm/headers.am (unfollow)
2021-09-21build: Remove old build systemSebastian Huber1-54/+0
Close #3250. Close #4081.
2020-12-23Update header.amSebastian Huber1-0/+15
2020-12-23bsps/arm: Set VBAR in start.SSebastian Huber1-1/+0
Set the VBAR to the vector table in the start section before bsp_start_hook_0() is called to earlier handle exceptions in RTEMS. Set the VBAR to the normal vector table in start.S for the main processor. Secondary processors set it in bsp_start_hook_0(). Update #4202.
2020-12-02bsps: Move zynq-uart to bsps/sharedKinsey Moore1-2/+0
This moves the zynq-uart driver from bsps/arm/shared to bsps/shared to accomodate use by AArch64 BSPs.
2020-10-05bsps: Break out AArch32 GICv3 supportKinsey Moore1-4/+0
This breaks out AArch32-specific code so that the shared GICv3 code can be reused by other architectures.
2020-10-05Move ARM PL011 UART driverKinsey Moore1-2/+0
This UART driver is now needed for BSPs other than ARM.
2019-04-11bsp/zynq-uart: Move Zynq UART driver to shared directoryJeff Kubascik1-0/+2
This driver will be shared with the xilinx-zynqmp BSP. Update #3682.
2018-07-05bsps: Update headers.amSebastian Huber1-0/+1
2018-01-25Remove make preinstallChris Johns1-0/+45
