Closes #3611.
The code covered by BSP_GET_WORK_AREA_DEBUG was basically dead code
since there was no normal way to activate it (e.g. via a BSP
configuration option). A follow up patch will bring back this feature
through a CONFIGURE_VERBOSE_SYSTEM_INITIALIZATION configuration option.
Update #3838.
Update #3706.
replace.
searching and sorting.
Update #3706.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
This avoids potential dead code in _Thread_Handler(). It gets rid of
the dangerous function pointer casts.
Update #2514.
do
echo $b
# echo $g
-i $b
done
The syscall functions overlapped with RTEMS, for example _write, _read, etc.
Change these to be internal to the BSP and avoid any clash with names in
RTEMS. Add support for SWI_Write0.
Change the console driver to use SWI_Write0. This outputs the character
to the host's stdout. Writing to file name 0 is not captured and managed
by GDB's simulation code while the SWI_Write0 is. The managed stdout
data is encapulated in the MI protocol while writes to file handle 0 are
dropped by GDB when in MI mode.
* .cvsignore, ChangeLog, Makefile.am, bsp_specs, configure.ac,
preinstall.am, console/.cvsignore, console/console-io.c,
include/.cvsignore, include/bsp.h, include/irq.h, include/swi.h,
start/.cvsignore, start/start.S, startup/.cvsignore,
startup/bspreset.c, startup/bspstart.c, startup/linkcmds,
startup/syscalls.c: New files.
* include/bsp.h: BSP does not have much memory. Limited to BIOS space.
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.ac,
preinstall.am, console/console-io.c, include/.cvsignore,
include/bsp.h, start/start.S, startup/bsppanic.c, startup/cmain.c,
startup/linkcmds: New files.
* include/bsp.h: Remove unnecessary boilerplate comments.
* include/bsp.h: Review of all bsp_cleanup() implementations. In this
phase, all prototypes were removed from bsp.h and empty
implementations were removed and made to use the shared stub.
* include/bsp.h, startup/bspstart.c: Eliminate copies of the
Configuration Table. Use the RTEMS provided accessor macros to obtain
configuration fields.
* include/bsp.h: New header guard.
* include/tm27.h: New.
PR 613/bsps
PR 614/bsps
* start/start.S: Include <rtems/asm.h> instead of <asm.h>.
* clock/clockdrv.c, include/bsp.h, startup/bspstart.c,
timer/timer.c: Convert to using c99 fixed size types.
* console/console-io.c, include/bsp.h, startup/bspclean.c,
startup/bspstart.c, timer/timer.c, tools/runtest: URL for license
changed.
* include/.cvsignore: Add bspopts.h*, coverhd.h, stamp-h*.
* include/bsp.h (Clear_tm27_intr): Stop the timer and disable
the interrupt. This was not quite right before and we were
getting uncontrolled interrupt nesting in tm27.
* timer/timer.c (Timer_Initialize): Added an extra reset and
changed the ITMR register so we will never get an interrupt.
(Read_timer): Fixed so the timer actually stops before it
is read. Before some times reported were outraguously high.
* start/start.S: Major clean including using stack in linkcmds,
deleting unused code, and zeroing the BSS using the linkcmds
information.
* startup/linkcmds: Put heap in lower memory than workspace
and move _clear_end so both are zeroed.
* include/bsp.h, timer/timer.c: Updated so timer appears to
work and support tm27. I would prefer to time a software
interrupt rather than an use an extra timer though.
* clock/clockdrv.c: Clean up.
* include/bsp.h: Uncomment and fix set_vector() prototype.
* Makefile.am: Added tools subdirectory and removed commented out line.
* configure.in: Added tools subdirectory.
* tools: New subdirectory.
* tools/.cvsignore, tools/Makefile.am, tools/configure.in,
tools/runtest: New files -- based on powerpc/psim.
* clock/clockdrv.c: Guessed new value for clock tick. Need to
add fast idle support.
* include/bsp.h: tm27 support initiated.
* start/start.S: Fixed frame/endframe problems on _sys_exit.
* startup/bspstart.c: Increased Workspace size to 4 MBYTES!
* linkcmds: Increased Workspace size to 4 MBYTES!
* Most tests appear to run correctly!
* README: Updated. We are now vectoring a clock tick ISR handler.
But RTEMS is not returning from the ISR properly.
* clock/clockdrv.c: Now causes interrupts but has not been calibrated.
* include/bsp.h: Use <libcpu/tx3904.h>
* startup/Makefile.am: Add setvec.c from shared.
* startup/bspstart.c: Initialize the status register (SR) so
no interrupts are masked but global interrupts (SR_IEC) are off.
Added call to install the ISR prologue code.
* wrapup/Makefile.am: Pick up more pieces from libcpu.
* The JMR BSP is for a Toshiba TX39 evaluation board but
can also be used with the mips simulator in gdb.
configure.in, clock/.cvsignore, clock/Makefile.am,
clock/clockdrv.c, console/.cvsignore, console/Makefile.am,
include/Makefile.am, include/bsp.h, start/.cvsignore,
start/Makefile.am, start/regs.S, start/start.S,
startup/.cvsignore, startup/Makefile.am, startup/bspstart.c,
startup/linkcmds, wrapup/.cvsignore, wrapup/Makefile.am: New files.
by gdb 5.0's i960 simulator) is enough to run hello world.
based on the GNU tools. This usually involved correcting the
type of bsp_start(), bsp_cleanup(), adjusting the start code to
call the right start routine (the shared boot_card()), and then
removing code from bsp_start() which was performed in the new
boot_card()/main() path.
