path: root/bsps/arm/csb337/include/tm27.h (unfollow)
2019-03-08bsps: Adjust bsp.h Doxygen groupsSebastian Huber1-1/+1
Update #3706.
2018-11-12arm/csb337: Update Doxygen (GCI 2018)shashvatjain1-0/+9
2018-01-25Remove make preinstallChris Johns1-0/+0
2017-11-27bsps: Provide <tm27.h> in each BSPSebastian Huber1-0/+1
Since the <tm27.h> is highly BSP-dependent and used only by the tm27 test program we must provide this header file for each BSP. Without the preinstall build target each header file must have a unique source header file. Update #3254.
