line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
. added a README to pwm
. added select_pwmss() to select pwmss-generic registers, as opposed
to PWM-specific registers
. added pwmss_clock_en_status(), beagle_pwmss_is_running() and pwmss_tb_clock_check()
. other API improvements
. style improvements
This patch adapts the previously added Beaglebone PWM code from BBBIO to RTEMS.
This work was done in the context of the Google Summer of Code 2016, and further
patches will follow to improve the code quality and documentation.
This patch adds the PWM driver code for the Beaglebone Black from BBBIO:
https://github.com/VegetableAvenger/BBBIOlib/blob/master/BBBio_lib/BBBiolib_PWMSS.c
This commit is for tracking purposes only; the next commit will adapt the code for
RTEMS.
