* | bsps/arm/atsamv: Change license to BSD-2 | Joel Sherrill | 2022-07-08 | 11 | -33/+242 |
| | | | | Updates #3053. | ||||
* | bsps/arm/: Scripted embedded brains header file clean up | Joel Sherrill | 2022-03-10 | 11 | -66/+0 |
| | | | | Updates #4625. | ||||
* | bsp_specs: Delete last remnants of these. | Joel Sherrill | 2021-11-29 | 1 | -0/+0 |
| | | | | Updates #3937. | ||||
* | build: Remove old build system | Sebastian Huber | 2021-09-21 | 1 | -39/+0 |
| | | | | | Close #3250. Close #4081. | ||||
* | bsps/irq: Use BSP_INTERRUPT_VECTOR_COUNT | Sebastian Huber | 2021-06-24 | 1 | -1/+1 |
| | | | | | | Use BSP_INTERRUPT_VECTOR_COUNT instead of BSP_INTERRUPT_VECTOR_MAX. Update #3269. | ||||
* | bsps: Replace bsp_specs with an empty file | Sebastian Huber | 2021-01-28 | 1 | -9/+0 |
| | | | | | | | This fixes an issue with the latest tool chain which adds the default linker script in the endfile specification. Update #3250. | ||||
* | Use RTEMS_SYSINIT_ORDER_LAST_BUT_5 | Sebastian Huber | 2020-02-04 | 1 | -1/+1 |
| | | | | | | | | Use RTEMS_SYSINIT_ORDER_LAST_BUT_5 instead of RTEMS_SYSINIT_ORDER_LAST to allow applications and support functions to place system initialization handlers behind the standard handlers. Update #3838. | ||||
* | bsp/atsam: Enable configuration of SDRAMC_LPR | Sebastian Huber | 2019-06-21 | 1 | -4/+8 |
* | atsam: Add ATSAM_POWER_WAIT_MODE | Sebastian Huber | 2019-06-18 | 1 | -0/+195 |
* | atsam: Enable fast startup via RTC alarm | Sebastian Huber | 2019-06-18 | 1 | -0/+6 |
* | bsp/atsam: Use proper API | Sebastian Huber | 2019-06-18 | 1 | -4/+1 |
* | bsp/atsam: Do not disable the WDT | Sebastian Huber | 2019-06-13 | 1 | -1/+0 |
| | | | | | The watchdog timer (WDT) can be configure only once. Do not touch it in the BSP since the application may want to use it. | ||||
* | bsp/atsam: Improve RTC power driver | Sebastian Huber | 2019-06-13 | 1 | -9/+22 |
| | | | | Accept a time interval up to 24h. | ||||
* | bsp/atsam: Use internal SRAM for stack area | Sebastian Huber | 2018-10-04 | 1 | -1/+1 |
* | bsp/atsam: Move libraries to bsps | Sebastian Huber | 2018-04-23 | 1 | -0/+49 |
| | | | | | | This patch is a part of the BSP source reorganization. Update #3285. | ||||
* | bsps: Move startup files to bsps | Sebastian Huber | 2018-04-20 | 16 | -0/+902 |
Adjust build support files to new directory layout. This patch is a part of the BSP source reorganization. Update #3285. |
