path: root/bsps/arm/atsam/include/libchip/include/same70/same70q21.h (unfollow)
2018-01-25Remove make preinstallChris Johns1-0/+0
2016-01-19bsp/atsam: Port SAM Software Package to RTEMSSebastian Huber1-0/+2
Update #2529.
2016-01-19bsp/atsam: Import SAM Software PackageSebastian Huber1-0/+687
Import selected files of the "SAM V71 / V70 / E70 / S70 Software Package" obtained from the "SAMV71-XULT GNU Software Package 1.5". Converted files via dos2unix before import. Update #2529.
