This adds SMP support for AArch64 in cpukit and for the ZynqMP BSPs.
Add the stub necessary to boot on AArch64 under EL2 and drop to EL1 for
normal operation.
Run with stack alignment faults enabled under RTEMS_DEBUG to catch any
stack misalignments early. This makes it easier to track them down
should they ever occur.
Remove usage of SUBALIGN() in aarch64 linkcmds which works around a
difference in behavior on AArch64 platforms. This is no longer necessary
since alignment is now enforced explicitly.
Closes #4178.
Sort alphabetically.
GCC 11 uses DWARF 5 by default.
The SUBALIGN(4) required on rtemsroset and rtemsrwset for ILP32 builds
was previously present on LP64 builds and causes no issues within RTEMS,
but causes relocation/alignment issues when building libbsd. This
restricts those alignment changes to ILP32 builds.
This adds an AArch64 ILP32 BSP variant based on Qemu's Cortex-A53
emulation with interrupt support using GICv3 and clock support using
the ARM GPT.
This adds an AArch64 basic BSP based on Qemu's Cortex-A53 emulation with
interrupt support using GICv3 and clock support using the ARM GPT.
