* config.sub: Remove (Automatically added by automake, again).
* bootstrap: Reflect change above.
* configure.ac: Require automake >= 1.7.6.
* bootstrap: Reflect having added config.sub.
* bootstrap: Remove attempts to detect autoconf and automake using
"which" (PR 325).
* bootstrap: Require autoconf 2.54 or 2.57.
Require automake-1.7.2.
* bootstrap: Allow autoconf-2.57.
* bootstrap: Allow autoconf-2.56.
* bootstrap: Allow autoconf > 2.52, automake > 1.6.
* bootstrap: Add generate_bspdir_acinclude to automatically update
c/src/lib/libbsp/<cpu>/acinclude.m4.
Use #! /bin/sh instead of #!/bin/sh.
Remove autom4te*.cache during ./bootstrap --clean.
* bootstrap: Add autoconf/automake version checks by popular demand.
[FWIW: I dislike this.]
* aclocal/version.m4: New file.
* aclocal/rtems-top.m4: Add RTEMS_VERSIONING, replace VERSION w/
aclocal/version.m4.
* bootstrap: Use aclocal/version.m4 instead of VERSION.
* configure.ac: Use aclocal/version.m4 instead of VERSION.
* aclocal/sysv-ipc.m4: Use 3-args AC_DEFINE for autoconf-2.5x
compatibility.
* bootstrap: Let --clean remove texinfo.tex.
* bootstrap: Run autoheader when configure.ac contains
RTEMS_BSP_CONFIGURE. Remove bspopts.h* files.
* bootstrap: remove/add automake added files.
* .cvsignore: reflect changes to bootstrap.
* configure.in: autoupdate to autoconf-2.52.
* bootstrap: Add handling for configure.ac, make autoheader verbose,
fix auto*tool invocation order.
* aclocal/rtems-test-no-pause.m4: Introduce AC_HELP_STRING.
* aclocal/enable-bare.m4: Introduce AC_HELP_STRING.
* aclocal/enable-cxx.m4: Introduce AC_HELP_STRING.
* aclocal/enable-gcc28: Introduce AC_HELP_STRING.
* aclocal/enable-inlines.m4: Introduce AC_HELP_STRING.
* aclocal/enable-itron.m4: Introduce AC_HELP_STRING.
* aclocal/enable-libcdir.m4: Introduce AC_HELP_STRING.
* aclocal/enable-multiprocessing.m4: Introduce AC_HELP_STRING.
* aclocal/enable-networking.m4: Introduce AC_HELP_STRING.
* aclocal/enable-posix.m4: Introduce AC_HELP_STRING.
* aclocal/enable-rdbg.m4: Introduce AC_HELP_STRING.
* aclocal/enable-rtemsbsp.m4: Introduce AC_HELP_STRING.
* aclocal/enable-tests.m4: Introduce AC_HELP_STRING.
* aclocal/env-rtemsbsp.m4: Add AC_ARC_VAR(RTEMS_BSP), apply true in
RTEMS_CONFIG_PER_BSP conditional.
* aclocal/multilib.m4: Introduce AC_HELP_STRING.
* aclocal/rtems-debug.m4: Introduce AC_HELP_STRING.
* aclocal/rtems-top.m4: Add AC_PREFIX_DEFAULT(/opt/rtems).
<corsepiu@faw.uni-ulm.de> to evaluate ACLOCAL_AMFLAGS in
Makefile.ams before running aclocal.
Remark: This patch is in preparation to switching to Cygnus/GNU
canonicalization. I plan to introduce to an alternate aclocal macros
directory which shall contain Cygnus/GNU conforming macros only,
soon.
<corsepiu@faw.uni-ulm.de> which does the following:
This is the configuration cleanup patch:
Main changes:
* TARGET_ARCH removed
* target.cfg.in moved to c/make/target.cfg.in (Only configured once for
all BSPs of a target)
* BARE_XXX variables appended to bsp.cfg.in
* autogen renamed to bootstrap
* removed stray variables from make/custom/*.cfg
rm c/src/make/target.cfg.in
cp autogen bootstrap
mkdir c/make
cp make/target.cfg.in c/make/target.cfg.in
rm make/target.cfg.in
rm autogen
patch -p1 < rtems-rc-19991105-1.diff
