path: root/bootstrap (follow)
* 2011-10-03 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-10-031-2/+2
| | | | | | * depcomp, compile, texinfo.tex, mdate-sh: New. * bootstrap (-c): Don't remove depcomp, compile, texinfo.tex, mdate-sh.
* 2011-02-03 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-03-031-1/+4
| | | | | * bootstrap: Add -g option. Switch default to autoreconf.
* 2008-04-14 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2008-04-141-1/+1
| | | | * bootstrap: Use find . ... preinstall.am for portability reasons.
* Add -r (autoreconf).Ralf Corsepius2006-11-181-0/+25
* 2006-11-18 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2006-11-181-4/+17
| | | | * bootstrap: Add -p (regenerate preinstall.ams).
* 2006-02-01 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2006-02-011-1/+1
| | | | | PR 882/make_build * bootstrap: Only remove bspopts.h.in instead of bspopts.h*.
* 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-121-2/+2
| | | | * bootstrap: RTEMS_CHECK_BSPDIR(RTEMS_BSP_FAMILY).
* 2004-01-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-091-1/+1
| | | | | * .cvsignore: Remove mkinstalldirs. * bootstrap: Remove compile during "clean".
* 2003-10-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-10-201-2/+1
| | | | | * bootstrap: Use $RTEMS_BSP_FAMILY instead of RTEMS_BSP_ALIAS in c/src/lib/libbsp/*/acinclude.m4.
* 2003-07-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-131-3/+1
| | | | | | * config.sub: Remove (Automatically added by automake, again). * bootstrap: Reflect change above. * configure.ac: Require automake >= 1.7.6.
* 2003-06-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-06-181-1/+5
| | | | * bootstrap: Reflect having added config.sub.
* Merger from rtems-4-6-branch.Ralf Corsepius2003-03-251-26/+21
* 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-02-111-3/+3
| | | | | * bootstrap: Remove attempts to detect autoconf and automake using "which" (PR 325).
* 2002-12-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-091-2/+2
| | | | | * bootstrap: Require autoconf 2.54 or 2.57. Require automake-1.7.2.
* 2002-12-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-041-2/+2
| | | | * bootstrap: Allow autoconf-2.57.
* 2002-11-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-151-1/+1
| | | | * bootstrap: Allow autoconf-2.56.
* 2002-11-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-071-6/+4
| | | | * bootstrap: Allow autoconf > 2.52, automake > 1.6.
* 2002-10-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-301-1/+35
| | | | | | | * bootstrap: Add generate_bspdir_acinclude to automatically update c/src/lib/libbsp/<cpu>/acinclude.m4. Use #! /bin/sh instead of #!/bin/sh. Remove autom4te*.cache during ./bootstrap --clean.
* 2002-10-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-091-0/+30
| | | | | * bootstrap: Add autoconf/automake version checks by popular demand. [FWIW: I dislike this.]
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-281-2/+2
| | | | | | | | * aclocal/version.m4: New file. * aclocal/rtems-top.m4: Add RTEMS_VERSIONING, replace VERSION w/ aclocal/version.m4. * bootstrap: Use aclocal/version.m4 instead of VERSION. * configure.ac: Use aclocal/version.m4 instead of VERSION.
* 2002-01-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-241-1/+2
| | | | | | * aclocal/sysv-ipc.m4: Use 3-args AC_DEFINE for autoconf-2.5x compatibility. * bootstrap: Let --clean remove texinfo.tex.
* 2001-12-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-071-0/+3
| | | | | * bootstrap: Run autoheader when configure.ac contains RTEMS_BSP_CONFIGURE. Remove bspopts.h* files.
* 2001-09-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-211-2/+2
| | | | | * bootstrap: remove/add automake added files. * .cvsignore: reflect changes to bootstrap.
* 2001-07-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-131-3/+5
| | | | | | | | | | | | | | | | | | | | | | | | * configure.in: autoupdate to autoconf-2.52. * bootstrap: Add handling for configure.ac, make autoheader verbose, fix auto*tool invocation order. * aclocal/rtems-test-no-pause.m4: Introduce AC_HELP_STRING. * aclocal/enable-bare.m4: Introduce AC_HELP_STRING. * aclocal/enable-cxx.m4: Introduce AC_HELP_STRING. * aclocal/enable-gcc28: Introduce AC_HELP_STRING. * aclocal/enable-inlines.m4: Introduce AC_HELP_STRING. * aclocal/enable-itron.m4: Introduce AC_HELP_STRING. * aclocal/enable-libcdir.m4: Introduce AC_HELP_STRING. * aclocal/enable-multiprocessing.m4: Introduce AC_HELP_STRING. * aclocal/enable-networking.m4: Introduce AC_HELP_STRING. * aclocal/enable-posix.m4: Introduce AC_HELP_STRING. * aclocal/enable-rdbg.m4: Introduce AC_HELP_STRING. * aclocal/enable-rtemsbsp.m4: Introduce AC_HELP_STRING. * aclocal/enable-tests.m4: Introduce AC_HELP_STRING. * aclocal/env-rtemsbsp.m4: Add AC_ARC_VAR(RTEMS_BSP), apply true in RTEMS_CONFIG_PER_BSP conditional. * aclocal/multilib.m4: Introduce AC_HELP_STRING. * aclocal/rtems-debug.m4: Introduce AC_HELP_STRING. * aclocal/rtems-top.m4: Add AC_PREFIX_DEFAULT(/opt/rtems).
* Patch rtems-rc-20000614-2-cvs.diff from Ralf CorsepiusJoel Sherrill2000-06-141-3/+7
| | | | | | | | | | <corsepiu@faw.uni-ulm.de> to evaluate ACLOCAL_AMFLAGS in Makefile.ams before running aclocal. Remark: This patch is in preparation to switching to Cygnus/GNU canonicalization. I plan to introduce to an alternate aclocal macros directory which shall contain Cygnus/GNU conforming macros only, soon.
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-7/+15
* Patch rtems-rc-19991105-1.diff.gz from Ralf CorsepiusJoel Sherrill1999-11-161-0/+114
<corsepiu@faw.uni-ulm.de> which does the following: This is the configuration cleanup patch: Main changes: * TARGET_ARCH removed * target.cfg.in moved to c/make/target.cfg.in (Only configured once for all BSPs of a target) * BARE_XXX variables appended to bsp.cfg.in * autogen renamed to bootstrap * removed stray variables from make/custom/*.cfg To apply: cd <source-tree> rm c/src/make/target.cfg.in cp autogen bootstrap mkdir c/make cp make/target.cfg.in c/make/target.cfg.in rm make/target.cfg.in rm autogen patch -p1 < rtems-rc-19991105-1.diff
