Closes #2965.
closes #2812.
Sorting removed the variations across different host operating systems
and file systems.
These modifications were required by hand after running the script.
In some cases, the file names did not match patterns. In others,
the format of the file did not match any common patterns.
* depcomp, compile, texinfo.tex, mdate-sh: New.
* bootstrap (-c): Don't remove depcomp, compile, texinfo.tex,
mdate-sh.
* bootstrap: Add -g option.
Switch default to autoreconf.
* bootstrap: Use find . ... preinstall.am for portability reasons.
* bootstrap: Add -p (regenerate preinstall.ams).
PR 882/make_build
* bootstrap: Only remove bspopts.h.in instead of bspopts.h*.
* bootstrap: RTEMS_CHECK_BSPDIR(RTEMS_BSP_FAMILY).
* .cvsignore: Remove mkinstalldirs.
* bootstrap: Remove compile during "clean".
* bootstrap: Use $RTEMS_BSP_FAMILY instead of RTEMS_BSP_ALIAS in
c/src/lib/libbsp/*/acinclude.m4.
* config.sub: Remove (Automatically added by automake, again).
* bootstrap: Reflect change above.
* configure.ac: Require automake >= 1.7.6.
* bootstrap: Reflect having added config.sub.
* bootstrap: Remove attempts to detect autoconf and automake using
"which" (PR 325).
* bootstrap: Require autoconf 2.54 or 2.57.
Require automake-1.7.2.
* bootstrap: Allow autoconf-2.57.
* bootstrap: Allow autoconf-2.56.
* bootstrap: Allow autoconf > 2.52, automake > 1.6.
* bootstrap: Add generate_bspdir_acinclude to automatically update
c/src/lib/libbsp/<cpu>/acinclude.m4.
Use #! /bin/sh instead of #!/bin/sh.
Remove autom4te*.cache during ./bootstrap --clean.
* bootstrap: Add autoconf/automake version checks by popular demand.
[FWIW: I dislike this.]
* aclocal/version.m4: New file.
* aclocal/rtems-top.m4: Add RTEMS_VERSIONING, replace VERSION w/
aclocal/version.m4.
* bootstrap: Use aclocal/version.m4 instead of VERSION.
* configure.ac: Use aclocal/version.m4 instead of VERSION.
* aclocal/sysv-ipc.m4: Use 3-args AC_DEFINE for autoconf-2.5x
compatibility.
* bootstrap: Let --clean remove texinfo.tex.
* bootstrap: Run autoheader when configure.ac contains
RTEMS_BSP_CONFIGURE. Remove bspopts.h* files.
* bootstrap: remove/add automake added files.
* .cvsignore: reflect changes to bootstrap.
* configure.in: autoupdate to autoconf-2.52.
* bootstrap: Add handling for configure.ac, make autoheader verbose,
fix auto*tool invocation order.
* aclocal/rtems-test-no-pause.m4: Introduce AC_HELP_STRING.
* aclocal/enable-bare.m4: Introduce AC_HELP_STRING.
* aclocal/enable-cxx.m4: Introduce AC_HELP_STRING.
* aclocal/enable-gcc28: Introduce AC_HELP_STRING.
* aclocal/enable-inlines.m4: Introduce AC_HELP_STRING.
* aclocal/enable-itron.m4: Introduce AC_HELP_STRING.
* aclocal/enable-libcdir.m4: Introduce AC_HELP_STRING.
* aclocal/enable-multiprocessing.m4: Introduce AC_HELP_STRING.
* aclocal/enable-networking.m4: Introduce AC_HELP_STRING.
* aclocal/enable-posix.m4: Introduce AC_HELP_STRING.
* aclocal/enable-rdbg.m4: Introduce AC_HELP_STRING.
* aclocal/enable-rtemsbsp.m4: Introduce AC_HELP_STRING.
* aclocal/enable-tests.m4: Introduce AC_HELP_STRING.
* aclocal/env-rtemsbsp.m4: Add AC_ARC_VAR(RTEMS_BSP), apply true in
RTEMS_CONFIG_PER_BSP conditional.
* aclocal/multilib.m4: Introduce AC_HELP_STRING.
* aclocal/rtems-debug.m4: Introduce AC_HELP_STRING.
* aclocal/rtems-top.m4: Add AC_PREFIX_DEFAULT(/opt/rtems).
<corsepiu@faw.uni-ulm.de> to evaluate ACLOCAL_AMFLAGS in
Makefile.ams before running aclocal.
Remark: This patch is in preparation to switching to Cygnus/GNU
canonicalization. I plan to introduce to an alternate aclocal macros
directory which shall contain Cygnus/GNU conforming macros only,
soon.
<corsepiu@faw.uni-ulm.de> which does the following:
This is the configuration cleanup patch:
Main changes:
* TARGET_ARCH removed
* target.cfg.in moved to c/make/target.cfg.in (Only configured once for
all BSPs of a target)
* BARE_XXX variables appended to bsp.cfg.in
* autogen renamed to bootstrap
* removed stray variables from make/custom/*.cfg
rm c/src/make/target.cfg.in
cp autogen bootstrap
mkdir c/make
cp make/target.cfg.in c/make/target.cfg.in
rm make/target.cfg.in
rm autogen
patch -p1 < rtems-rc-19991105-1.diff
preparations for automake.
releasing a snapshot:
1. Cleanup to aclocal/
cvs rm -f aclocal/cygwin.m4
cvs rm -f aclocal/exeext.m4
2. rtems-rc-19990328-0.diff
Some (minor) bug-fixes:
3. rtems-rc-19990328-1.diff
-ac -am -ci.
(reduces size of configure.in
description follows:
Description:
config.h.ins)
acpolish
configure scripts
Remarks:
[$(prefix)].
issues.
egcs/contrib/egcs_update).
ATTENTION:
* "make RTEMS_BSP=<bsp> dist"
This is the next step towards automake:
* Two scripts for the toplevel directory:
a) "autogen" (Idea borrowed from libtool and gnome) A helper script to
recursively regenerate autoconf/automake/aclocal generated files
(Still not perfect but sufficient).
b) "missing" (from automake-cvs archive). This file normally is
automatically generated by automake, but we have to manually add
it until we add automake support to the toplevel configure script.
"chmod 755 missing autogen" after applying the patch.
* Changing the toplevel installation directory [ I can hear you
falling off the chair ;-]
Until now rtems installed itself to $(prefix)/rtems. This is in
contradiction to automake and GNU/FSF/Cygnus conventions.
With this patch applied, rtems installs into $(prefix).
To achieve the old behaviour simply configure with
--prefix=<install-dir>/rtems instead of --prefix=<install-dir>
This is a widely visible change and I can understand if you don't
like it at the present point. It enables us to use automake's
default installation paths instead of having to set up installation
paths manually. At the moment this doesn't help much, but in the not
so far future this would enable us to mix cpu-only dependent libraries
into the host's cross-compiler library and header files into
newlib's include directories, tools into the toolchain directories etc.
I would recommend to change the main installation directory, however it's
up to you to draw the final design decision.
