path: root/bootstrap (follow)
* 2001-07-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-131-3/+5
| | | | | | | | | | | | | | | | | | | | | | | | * configure.in: autoupdate to autoconf-2.52. * bootstrap: Add handling for configure.ac, make autoheader verbose, fix auto*tool invocation order. * aclocal/rtems-test-no-pause.m4: Introduce AC_HELP_STRING. * aclocal/enable-bare.m4: Introduce AC_HELP_STRING. * aclocal/enable-cxx.m4: Introduce AC_HELP_STRING. * aclocal/enable-gcc28: Introduce AC_HELP_STRING. * aclocal/enable-inlines.m4: Introduce AC_HELP_STRING. * aclocal/enable-itron.m4: Introduce AC_HELP_STRING. * aclocal/enable-libcdir.m4: Introduce AC_HELP_STRING. * aclocal/enable-multiprocessing.m4: Introduce AC_HELP_STRING. * aclocal/enable-networking.m4: Introduce AC_HELP_STRING. * aclocal/enable-posix.m4: Introduce AC_HELP_STRING. * aclocal/enable-rdbg.m4: Introduce AC_HELP_STRING. * aclocal/enable-rtemsbsp.m4: Introduce AC_HELP_STRING. * aclocal/enable-tests.m4: Introduce AC_HELP_STRING. * aclocal/env-rtemsbsp.m4: Add AC_ARC_VAR(RTEMS_BSP), apply true in RTEMS_CONFIG_PER_BSP conditional. * aclocal/multilib.m4: Introduce AC_HELP_STRING. * aclocal/rtems-debug.m4: Introduce AC_HELP_STRING. * aclocal/rtems-top.m4: Add AC_PREFIX_DEFAULT(/opt/rtems).
* Patch rtems-rc-20000614-2-cvs.diff from Ralf CorsepiusJoel Sherrill2000-06-141-3/+7
| | | | | | | | | | <corsepiu@faw.uni-ulm.de> to evaluate ACLOCAL_AMFLAGS in Makefile.ams before running aclocal. Remark: This patch is in preparation to switching to Cygnus/GNU canonicalization. I plan to introduce to an alternate aclocal macros directory which shall contain Cygnus/GNU conforming macros only, soon.
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-7/+15
* Patch rtems-rc-19991105-1.diff.gz from Ralf CorsepiusJoel Sherrill1999-11-161-0/+114
<corsepiu@faw.uni-ulm.de> which does the following: This is the configuration cleanup patch: Main changes: * TARGET_ARCH removed * target.cfg.in moved to c/make/target.cfg.in (Only configured once for all BSPs of a target) * BARE_XXX variables appended to bsp.cfg.in * autogen renamed to bootstrap * removed stray variables from make/custom/*.cfg To apply: cd <source-tree> rm c/src/make/target.cfg.in cp autogen bootstrap mkdir c/make cp make/target.cfg.in c/make/target.cfg.in rm make/target.cfg.in rm autogen patch -p1 < rtems-rc-19991105-1.diff
