* automake/compile.am: Add LD.
* automake/lib.am: Add LD.
* configure.in: New, Cygnus/GNU style configuration.
* Makefile.am: Add macros/, reflect new configure.in,
ACLOCAL_AMFLAGS = -I $(RTEMS_TOPdir)/macros
* automake/compile.am: BSP_SPECS, remove RTEMS_CANONICALIZATION.
* automake/lib.am: Remove RTEMS_CANONICALIZATION.
* macros/tool-prefix.m4: Remove.
* macros/target.m4: Remove RTEMS_CONFIG_SUBDIRS, RTEMS_OUTPUT_SUBDIRS.
* macros/enable-rtemsbsp.m4: Add RTEMS_CONFIG_PER_BSP, add setting
RTEMS_ROOT.
* macros/i386-gas-code16.m4: Define NEW_GAS only for 16bit mode-
* macros/multilib.m4: Various minor fixes.
* macros/project-root.m4: Remove setting PROJECT_TOPdir,
PROJECT_ROOT, RTEMS_ROOT.
* macros/rtems-top.m4: Remove RTEMS_CANONICALIZATION, TARGET_SUBDIRS;
Add with_target_subdirs, PROJECT_TOPdir, PROJECT_ROOT.
* automake/multilib.am: New file.
* Makefile.am: Update AUTOMAKE_FILES to reflect the contents of
the automake/ directory.
* macros/enable-hwapi.m4: Removed.
* aclocal/rtems-top.m4, automake/compile.am, automake/lib.am:
A small cleanup step towards gnu-canonicalization.
* automake/lib.am: Remove leaf.cfg.
* aclocal/rtems-top.m4: Add ENDIF-hack.
* automake/compile.am: Add include $(DEPENDS) + ENDIF-hack.
* aclocal/check-cxx.m4: Add AC_SUBST(CPLUS_LD_LIBS)
* aclocal/prog-cc.m4: Cleanup comments, require RTEMS_ENABLE_GCC28,
add automake conditionals RTEMS_USE_GCC, RTEMS_USE_GCC272.
* automake/compile.am: Replaced.
* automake/local.am: Remove building variant handling.
* aclocal/enable-rtemsbsp.m4: Add RTEMS_ENABLE_BARE,
AC_SUBST(BARE_CPU_MODEL),AC_SUBST(BARE_CPU_CFLAGS).
* aclocal/i386-gas-code16.m4: AC_DEFINE NEW_GAS.
* aclocal/target.m4: Cleanup comments
* Automake/compile.am: Add DEFS support to keep building happy.
* automake/compile.am: New file
* ChangeLog: Fix email addresses
which is described below:
break something.
SUBDIRS in a Makefile.am)
* An update to gensh2.cfg.
cd <srcdir>
bugs.
rm -rf c/src/exec/score/cpu/i960/wrap
rm -rf c/src/exec/score/cpu/m68k/wrap
rm -rf c/src/exec/score/cpu/sh/wrap
rm -rf c/src/exec/score/cpu/sparc/wrap
rm -rf c/src/exec/score/cpu/unix/wrap
patch -p1 < rtems-rc-19991123-rc-1.diff
./bootstrap
Known bugs:
* "make debug|profile" in c/src/src/score/cpu/<RTEMS_CPU/Makefile does
not handle recursion to subdirectories correctly (recurses too often).
However, this issue is hardly visible and should be tolerable for the
moment.
<corsepiu@faw.uni-ulm.de>.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
CHANGES:
c/Makefile.am removed
still in - remove it?)
(Cygwin support)
REMARK:
inside the build-tree.
APPLYING THE PATCH
autogen
> * RTEMS's 'make depend' isn't a standard automake make target and is not
> supported in automake supported subdirectories.
preparations for automake.
description follows:
Description:
config.h.ins)
acpolish
configure scripts
Remarks:
[$(prefix)].
