path: root/automake (unfollow)
2018-10-10build: Remove local.amSebastian Huber1-3/+0
2018-01-25Remove make preinstallChris Johns3-30/+2
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill3-6/+0
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
2006-01-12Remove depend-recursive:Ralf Corsepius1-4/+0
2006-01-12Remove depend-am:Ralf Corsepius2-8/+0
2003-12-142003-12-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-213/+0
* automake/compile.am: Remove (Unused).
2003-12-122003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-23/+0
* automake/lib.am: Remove (Unused).
2003-12-112003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-12/+0
* configure.ac: Remove make/custom/Makefile. * Makefile.am: Cosmetics. * automake/compile.am: Remove compilation rules. Remove $(ARCH) directory generation.
2003-08-212003-08-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2-20/+0
* aclocal/bsp-arg-enable.m4, aclocal/bsp-configure.m4, aclocal/bspopts.m4, aclocal/canonicalize-tools.m4, aclocal/check-bsp-cache.m4, aclocal/check-cxx.m4, aclocal/check-itron.m4, aclocal/check-multiprocessing.m4, aclocal/check-networking.m4, aclocal/check-newlib.m4, aclocal/check-posix.m4, aclocal/check-rdbg.m4, aclocal/check-tool.m4, aclocal/env-rtemsbsp.m4, aclocal/gcc-isystem.m4, aclocal/gcc-pipe.m4, aclocal/gcc-specs.m4, aclocal/i386-gas-code16.m4, aclocal/path-perl.m4, aclocal/ppc.m4, aclocal/prog-cc.m4, aclocal/prog-ccas.m4, aclocal/prog-cxx.m4, aclocal/prog-gnat.m4, aclocal/rtems-debug.m4, aclocal/rtems-flags.m4, aclocal/rtems-test-no-pause.m4, aclocal/target.m4: Remove (Unused). * automake/leaf.am, automake/force-preinstall.am: Remove (Unused). * Makefile.am: Reflect changes above.
2003-08-182003-08-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2-16/+0
* automake/local.am, automake/host.am: Remove "debug".
2003-06-062003-06-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-8/+0
* automake/local.am: Remove $(ARCH), clean-local.
2003-05-272003-05-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius3-28/+8
PR 321: * aclocal/check-bsp-cache.m4: Remove support for profile-variant. * aclocal/env-rtemsbsp.m4 * automake/compile.am * automake/host.am * automake/local.am
2003-05-162003-05-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-5/+15
* aclocal/check-cxx.m4: Remove LIBSUFFIX_VA. * automake/compile.am: Remove LIBSUFFIX_VA. Merger from rtems-4-6-branch.
2003-01-212003-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-3/+0
* automake/compile.am: Remove CLEAN_DEPEND (Unused). Remove CLOBBER_DEPEND (Unused).
2003-01-202003-01-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-3/+0
* automake/local.am: Remove distclean-local.
2002-12-122002-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-3/+0
* automake/compile.am: Remove creating $(ARCH) in compilation rules.
2002-12-062002-12-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-7/+6
* automake/compile.am: Rework *FLAGS, AM_*FLAGS handling.
2002-12-062002-12-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-10/+5
* automake/compile.am: Remove hard-coded *_PROFILE_V. Add autoconf-supplied CPU_CFLAGS, CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V, CFLAGS_PROFILE_V. Remove CPPFLAGS_GCC.
2002-12-012002-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-20/+6
* automake/compile.am: Remove LDFLAGS_INCOMPLETE. Remove LDFLAGS. Add CCAS, CCASCOMPILE. Remove compilation rules for *.cpp, *.cxx, *.C. Use CCASCOMPILE to compile *.S. Add -pg to RTEMS_CFLAGS_PROFILE_V.
2002-11-192002-11-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-4/+1
* automake/compile.am: Remove LD_PATHS (Unused). * aclocal/check-newlib.m4: Adaptation to autoconf-2.5x (AC_TRY_LINK is announced obsolete).
2002-11-152002-11-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-10/+2
* automake/compile.am: Remove CFLAGS_DEBUG_OPTIMIZE_V, CXXFLAGS_DEBUG_OPTIMIZE_V, LDFLAGS_DEBUG_V, CFLAGS_DEFAULT. Support @CFLAGS@, @CXXFLAGS@.
2002-11-082002-11-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-5/+0
* automake/compile.am: Remove rel rule.
2002-07-222002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2-2/+10
* aclocal/bsp-configure.m4: Add RTEMS_CHECK_MULTIPROCESSING. * automake/compile.am: Add test -d $(ARCH) || mkdir $(ARCH) to all compilation rules (Work-around to an automake bug). * automake/lib.am: Add test -d $(ARCH) || mkdir $(ARCH) to make-library.
2002-06-302002-06-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-33/+0
* automake/multilib.am: Remove. * Makefile.am: Reflect change above.
2002-04-162002-04-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-46/+2
* automake/compile.am: Remove GCC272 support. Remove *.sh rule (unused). * configure.ac: Remove ENABLE_GCC28. Remove ENABLE_LIBCDIR.
2002-01-072002-01-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-1/+1
* automake/compile.am (LINK_LIB_RTEMS): Removed line continuation for last line to eliminate 100's of warnings.
2002-01-062002-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-3/+5
* aclocal/check-newlib.m4: Apply AS_IF. * aclocal/config-subdirs.m4: Remove _RTEMS_PUSH_BUILDDIR, _RTEMS_POP_BUILDDIR, _RTEMS_GIVEN_INSTALL, _RTEMS_SUB_SRCDIR. * aclocal/subdirs.m4: Fix comments, apply AS_IF. * aclocal/sysv-ipc.m4: Reflect autoconf-2.5x canonicalization changes. * aclocal/target.m4: Add _RTEMS_PUSH_BUILDDIR, _RTEMS_POP_BUILDDIR, _RTEMS_GIVEN_INSTALL, _RTEMS_SUB_SRCDIR. * automake/compile.am: Remove librtemsall from LINK_FILES.
2002-01-062002-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-2/+4
2001-12-202001-12-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-5/+5
* configure.ac: Reworked for multilibs, reflect changes to aclocal/*.m4. * aclocal/subdirs.m4: New file. * aclocal/multi.m4: New file, adopted from autoconf-2.52 w/ modifications. * aclocal/check-posix.m4: Apply AS_IF. * aclocal/config-subdirs.m4: Reflect changes to other m4-macros. * aclocal/env-rtemsbsp.m4: Add PROJECT_INCLUDE, PROJECT_RELEASE. Add AM_CONDITIONAL(MULTILIB). Adapt GCC_SPECS to multilibs. * aclocal/env-rtemscpu.m4: Remove RTEMS_BSP. Add support for MULTIBUILDTOP, MULTISUBDIR. Adapt GCC_SPECS to multilibs. Add PROJECT_INCLUDE, PROJECT_RELEASE, includedir, libdir. * aclocal/multilib.m4: Fix m4-quoting, adopt automake-1.5's OUTPUT_COMMANDS. * aclocal/project-root.m4: Remove PROJECT_INCLUDE, PROJECT_RELEASE. * aclocal/rtems-debug.m4: Minor cleanups. * aclocal/rtems-top.m4: Minor cleanups. * automake/compile.am: Further steps towards automake's rules.
2001-12-182001-12-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2-6/+8
* automake/multilib.am: include @RTEMS_BSP@.cfg, cleanup. * automake/lib.am: Add MULTISUBDIR.
2001-11-202001-11-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+4
* automake/force-preinstall.am: New file. * aclocal/ppc.m4: New file.
2001-10-292001-10-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill3-15/+29
* Adopt more automake rules: * automake/compile.am: Add LINK, CXXLINK, AS, ASCOMPILE; Remove ARFLAGS, LINK.c, COMPILE.S, LINK.cc; Add CPU_CFLAGS to CXXFLAGS, CFLAGS, ASFLAGS; * automake/leaf.am: Add CXXLINK_APP, LINK_APP, make-exe, apply CXXLINK_APP in make-cxx-exe. * automake/lib.am: Add ARFLAGS.
2001-10-102001-10-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-11/+17
* automake/compile.am: Fundamentally reworked compilation rules for closer adaptation to automake's behavior.
2001-09-272001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+1
* automake/lib.am: Comment out LD. * Makefile.am: Use ACLOCAL_FILES = to make automake-1.5 happy; Add automake/leaf.am to AUTOMAKE_FILES.
2001-09-192001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+9
* automake/leaf.am: New file.
2001-04-262001-04-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-2/+2
* README.cdn-X: Update. * automake/compile.am: Remove -ansi -fasm from CFLAGS_DEFAULT, add @CPPFLAGS@ to CPPFLAGS.
2001-01-292001-01-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-14/+7
* aclocal/enable-rtemsbsp.m4: Split out RTEMS_ENV_RTEMSBSP, RTEMS_ENV_RTEMSCPU. * aclocal/env-rtemsbsp.m4: New file for RTEMS_ENV_RTEMSBSP, add special treatment for GCC_SPECS. * aclocal/env-rtemscpu.m4: New file for RTEMS_ENV_RTEMSCPU, add special treatment for GCC_SPECS. * aclocal/bsp-enable-arg.m4: New file, introduce RTEMS_BSP_ARG_ENABLE. * aclocal/prog-cc.m4: Add AC_PROG_CPP, use build_os in GCCSED hack. * automake/compile.am: New treatment of CPP, GCCSPECS, use `..` instead of $(shell ..) for LIBC_LIB*.
2001-01-032001-01-03 Emmanuel Raguet <raguet@crf.canon.fr>Joel Sherrill1-0/+1
* automake/compile.am: Add LD.
2000-11-022000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+1
* automake/lib.am: Add LD.
2000-10-312000-10-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2-29/+5
* configure.in: New, Cygnus/GNU style configuration. * Makefile.am: Add macros/, reflect new configure.in, ACLOCAL_AMFLAGS = -I $(RTEMS_TOPdir)/macros * automake/compile.am: BSP_SPECS, remove RTEMS_CANONICALIZATION. * automake/lib.am: Remove RTEMS_CANONICALIZATION. * macros/tool-prefix.m4: Remove. * macros/target.m4: Remove RTEMS_CONFIG_SUBDIRS, RTEMS_OUTPUT_SUBDIRS. * macros/enable-rtemsbsp.m4: Add RTEMS_CONFIG_PER_BSP, add setting RTEMS_ROOT. * macros/i386-gas-code16.m4: Define NEW_GAS only for 16bit mode- * macros/multilib.m4: Various minor fixes. * macros/project-root.m4: Remove setting PROJECT_TOPdir, PROJECT_ROOT, RTEMS_ROOT. * macros/rtems-top.m4: Remove RTEMS_CANONICALIZATION, TARGET_SUBDIRS; Add with_target_subdirs, PROJECT_TOPdir, PROJECT_ROOT.
2000-10-27Missed in earlier commits.Joel Sherrill1-0/+4
2000-10-272000-10-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+31
* automake/multilib.am: New file. * Makefile.am: Update AUTOMAKE_FILES to reflect the contents of the automake/ directory.
2000-10-242000-10-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2-0/+11
* macros/enable-hwapi.m4: Removed. * aclocal/rtems-top.m4, automake/compile.am, automake/lib.am: A small cleanup step towards gnu-canonicalization.
2000-09-142000-09-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-2/+0
* automake/lib.am: Remove leaf.cfg.
2000-09-132000-09-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+6
* aclocal/rtems-top.m4: Add ENDIF-hack. * automake/compile.am: Add include $(DEPENDS) + ENDIF-hack.
2000-09-122000-09-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2-48/+285
* aclocal/check-cxx.m4: Add AC_SUBST(CPLUS_LD_LIBS) * aclocal/prog-cc.m4: Cleanup comments, require RTEMS_ENABLE_GCC28, add automake conditionals RTEMS_USE_GCC, RTEMS_USE_GCC272. * automake/compile.am: Replaced. * automake/local.am: Remove building variant handling.
2000-09-122000-09-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+12
* aclocal/enable-rtemsbsp.m4: Add RTEMS_ENABLE_BARE, AC_SUBST(BARE_CPU_MODEL),AC_SUBST(BARE_CPU_CFLAGS). * aclocal/i386-gas-code16.m4: AC_DEFINE NEW_GAS. * aclocal/target.m4: Cleanup comments * Automake/compile.am: Add DEFS support to keep building happy.
2000-09-052000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+6
* automake/compile.am: New file * ChangeLog: Fix email addresses
2000-06-12Merged from 4.5.0-beta3aJoel Sherrill3-15/+93
2000-01-07Patch rtems-rc-20000104-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-2/+2
which is described below: This one is a (minor) patch in preparation of the upcoming patches. It actually is an excerpt of the upcoming patches and therefore is completely untested in this standalone form, but I don't expect it to break something. The essential changes in this patch are: * An update to rtems-polish.sh (Now can also be run in subdirectories) * A bug-fix for the libcpu/powerpc (A directory was missing from SUBDIRS in a Makefile.am) * An update to gensh2.cfg. * Cleanups/Enhancements to configuration files To apply: cd <srcdir> patch -p0 < rtems-rc-20000104-0.diff cvs rm -f c/src/lib/libbsp/Makefile.am.new
