path: root/automake (follow)
* 2002-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-121-3/+0
| | | | * automake/compile.am: Remove creating $(ARCH) in compilation rules.
* 2002-12-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-061-7/+6
| | | | * automake/compile.am: Rework *FLAGS, AM_*FLAGS handling.
* 2002-12-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-061-10/+5
| | | | | | | * automake/compile.am: Remove hard-coded *_PROFILE_V. Add autoconf-supplied CPU_CFLAGS, CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V, CFLAGS_PROFILE_V. Remove CPPFLAGS_GCC.
* 2002-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-011-20/+6
| | | | | | | | | * automake/compile.am: Remove LDFLAGS_INCOMPLETE. Remove LDFLAGS. Add CCAS, CCASCOMPILE. Remove compilation rules for *.cpp, *.cxx, *.C. Use CCASCOMPILE to compile *.S. Add -pg to RTEMS_CFLAGS_PROFILE_V.
* 2002-11-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-191-4/+1
| | | | | | * automake/compile.am: Remove LD_PATHS (Unused). * aclocal/check-newlib.m4: Adaptation to autoconf-2.5x (AC_TRY_LINK is announced obsolete).
* 2002-11-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-151-10/+2
| | | | | | * automake/compile.am: Remove CFLAGS_DEBUG_OPTIMIZE_V, CXXFLAGS_DEBUG_OPTIMIZE_V, LDFLAGS_DEBUG_V, CFLAGS_DEFAULT. Support @CFLAGS@, @CXXFLAGS@.
* 2002-11-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-081-5/+0
| | | | * automake/compile.am: Remove rel rule.
* 2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-222-2/+10
| | | | | | | | * aclocal/bsp-configure.m4: Add RTEMS_CHECK_MULTIPROCESSING. * automake/compile.am: Add test -d $(ARCH) || mkdir $(ARCH) to all compilation rules (Work-around to an automake bug). * automake/lib.am: Add test -d $(ARCH) || mkdir $(ARCH) to make-library.
* 2002-06-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-301-33/+0
| | | | | * automake/multilib.am: Remove. * Makefile.am: Reflect change above.
* 2002-04-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-161-46/+2
| | | | | | | * automake/compile.am: Remove GCC272 support. Remove *.sh rule (unused). * configure.ac: Remove ENABLE_GCC28. Remove ENABLE_LIBCDIR.
* 2002-01-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-071-1/+1
| | | | | * automake/compile.am (LINK_LIB_RTEMS): Removed line continuation for last line to eliminate 100's of warnings.
* 2002-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-061-3/+5
| | | | | | | | | | | | * aclocal/check-newlib.m4: Apply AS_IF. * aclocal/config-subdirs.m4: Remove _RTEMS_PUSH_BUILDDIR, _RTEMS_POP_BUILDDIR, _RTEMS_GIVEN_INSTALL, _RTEMS_SUB_SRCDIR. * aclocal/subdirs.m4: Fix comments, apply AS_IF. * aclocal/sysv-ipc.m4: Reflect autoconf-2.5x canonicalization changes. * aclocal/target.m4: Add _RTEMS_PUSH_BUILDDIR, _RTEMS_POP_BUILDDIR, _RTEMS_GIVEN_INSTALL, _RTEMS_SUB_SRCDIR. * automake/compile.am: Remove librtemsall from LINK_FILES.
* 2002-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-061-2/+4
* 2001-12-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-201-5/+5
| | | | | | | | | | | | | | | | | | | | * configure.ac: Reworked for multilibs, reflect changes to aclocal/*.m4. * aclocal/subdirs.m4: New file. * aclocal/multi.m4: New file, adopted from autoconf-2.52 w/ modifications. * aclocal/check-posix.m4: Apply AS_IF. * aclocal/config-subdirs.m4: Reflect changes to other m4-macros. * aclocal/env-rtemsbsp.m4: Add PROJECT_INCLUDE, PROJECT_RELEASE. Add AM_CONDITIONAL(MULTILIB). Adapt GCC_SPECS to multilibs. * aclocal/env-rtemscpu.m4: Remove RTEMS_BSP. Add support for MULTIBUILDTOP, MULTISUBDIR. Adapt GCC_SPECS to multilibs. Add PROJECT_INCLUDE, PROJECT_RELEASE, includedir, libdir. * aclocal/multilib.m4: Fix m4-quoting, adopt automake-1.5's OUTPUT_COMMANDS. * aclocal/project-root.m4: Remove PROJECT_INCLUDE, PROJECT_RELEASE. * aclocal/rtems-debug.m4: Minor cleanups. * aclocal/rtems-top.m4: Minor cleanups. * automake/compile.am: Further steps towards automake's rules.
* 2001-12-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-182-6/+8
| | | | | * automake/multilib.am: include @RTEMS_BSP@.cfg, cleanup. * automake/lib.am: Add MULTISUBDIR.
* 2001-11-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-201-0/+4
| | | | | * automake/force-preinstall.am: New file. * aclocal/ppc.m4: New file.
* 2001-10-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-293-15/+29
| | | | | | | | | | * Adopt more automake rules: * automake/compile.am: Add LINK, CXXLINK, AS, ASCOMPILE; Remove ARFLAGS, LINK.c, COMPILE.S, LINK.cc; Add CPU_CFLAGS to CXXFLAGS, CFLAGS, ASFLAGS; * automake/leaf.am: Add CXXLINK_APP, LINK_APP, make-exe, apply CXXLINK_APP in make-cxx-exe. * automake/lib.am: Add ARFLAGS.
* 2001-10-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-101-11/+17
| | | | | * automake/compile.am: Fundamentally reworked compilation rules for closer adaptation to automake's behavior.
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-271-1/+1
| | | | | | * automake/lib.am: Comment out LD. * Makefile.am: Use ACLOCAL_FILES = to make automake-1.5 happy; Add automake/leaf.am to AUTOMAKE_FILES.
* 2001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-191-0/+9
| | | | * automake/leaf.am: New file.
* 2001-04-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-04-261-2/+2
| | | | | | * README.cdn-X: Update. * automake/compile.am: Remove -ansi -fasm from CFLAGS_DEFAULT, add @CPPFLAGS@ to CPPFLAGS.
* 2001-01-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-291-14/+7
| | | | | | | | | | | | | * aclocal/enable-rtemsbsp.m4: Split out RTEMS_ENV_RTEMSBSP, RTEMS_ENV_RTEMSCPU. * aclocal/env-rtemsbsp.m4: New file for RTEMS_ENV_RTEMSBSP, add special treatment for GCC_SPECS. * aclocal/env-rtemscpu.m4: New file for RTEMS_ENV_RTEMSCPU, add special treatment for GCC_SPECS. * aclocal/bsp-enable-arg.m4: New file, introduce RTEMS_BSP_ARG_ENABLE. * aclocal/prog-cc.m4: Add AC_PROG_CPP, use build_os in GCCSED hack. * automake/compile.am: New treatment of CPP, GCCSPECS, use `..` instead of $(shell ..) for LIBC_LIB*.
* 2001-01-03 Emmanuel Raguet <raguet@crf.canon.fr>Joel Sherrill2001-01-031-0/+1
| | | | * automake/compile.am: Add LD.
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-021-0/+1
| | | | * automake/lib.am: Add LD.
* 2000-10-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-312-29/+5
| | | | | | | | | | | | | | | | | | * configure.in: New, Cygnus/GNU style configuration. * Makefile.am: Add macros/, reflect new configure.in, ACLOCAL_AMFLAGS = -I $(RTEMS_TOPdir)/macros * automake/compile.am: BSP_SPECS, remove RTEMS_CANONICALIZATION. * automake/lib.am: Remove RTEMS_CANONICALIZATION. * macros/tool-prefix.m4: Remove. * macros/target.m4: Remove RTEMS_CONFIG_SUBDIRS, RTEMS_OUTPUT_SUBDIRS. * macros/enable-rtemsbsp.m4: Add RTEMS_CONFIG_PER_BSP, add setting RTEMS_ROOT. * macros/i386-gas-code16.m4: Define NEW_GAS only for 16bit mode- * macros/multilib.m4: Various minor fixes. * macros/project-root.m4: Remove setting PROJECT_TOPdir, PROJECT_ROOT, RTEMS_ROOT. * macros/rtems-top.m4: Remove RTEMS_CANONICALIZATION, TARGET_SUBDIRS; Add with_target_subdirs, PROJECT_TOPdir, PROJECT_ROOT.
* Missed in earlier commits.Joel Sherrill2000-10-271-0/+4
* 2000-10-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-271-0/+31
| | | | | | * automake/multilib.am: New file. * Makefile.am: Update AUTOMAKE_FILES to reflect the contents of the automake/ directory.
* 2000-10-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-242-0/+11
| | | | | | * macros/enable-hwapi.m4: Removed. * aclocal/rtems-top.m4, automake/compile.am, automake/lib.am: A small cleanup step towards gnu-canonicalization.
* 2000-09-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-141-2/+0
| | | | * automake/lib.am: Remove leaf.cfg.
* 2000-09-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-131-0/+6
| | | | | * aclocal/rtems-top.m4: Add ENDIF-hack. * automake/compile.am: Add include $(DEPENDS) + ENDIF-hack.
* 2000-09-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-122-48/+285
| | | | | | | | * aclocal/check-cxx.m4: Add AC_SUBST(CPLUS_LD_LIBS) * aclocal/prog-cc.m4: Cleanup comments, require RTEMS_ENABLE_GCC28, add automake conditionals RTEMS_USE_GCC, RTEMS_USE_GCC272. * automake/compile.am: Replaced. * automake/local.am: Remove building variant handling.
* 2000-09-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-121-0/+12
| | | | | | | | * aclocal/enable-rtemsbsp.m4: Add RTEMS_ENABLE_BARE, AC_SUBST(BARE_CPU_MODEL),AC_SUBST(BARE_CPU_CFLAGS). * aclocal/i386-gas-code16.m4: AC_DEFINE NEW_GAS. * aclocal/target.m4: Cleanup comments * Automake/compile.am: Add DEFS support to keep building happy.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-051-0/+6
| | | | | * automake/compile.am: New file * ChangeLog: Fix email addresses
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-123-15/+93
* Patch rtems-rc-20000104-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-071-2/+2
| | | | | | | | | | | | | | | | | | | | | which is described below: This one is a (minor) patch in preparation of the upcoming patches. It actually is an excerpt of the upcoming patches and therefore is completely untested in this standalone form, but I don't expect it to break something. The essential changes in this patch are: * An update to rtems-polish.sh (Now can also be run in subdirectories) * A bug-fix for the libcpu/powerpc (A directory was missing from SUBDIRS in a Makefile.am) * An update to gensh2.cfg. * Cleanups/Enhancements to configuration files To apply: cd <srcdir> patch -p0 < rtems-rc-20000104-0.diff cvs rm -f c/src/lib/libbsp/Makefile.am.new
* Patch rtems-rc-19991123-rc-1.diff from Ralf CorsepiusJoel Sherrill1999-12-011-1/+1
| | | | | | | | | | | | | | | | | | | | | | | <corsepiu@faw.uni-ulm.de> which implements automake support for some score/cpu/<RTEMS_CPU> subdirectories and fixes a few minor configuration bugs. To apply: rm -rf c/src/exec/score/cpu/i960/wrap rm -rf c/src/exec/score/cpu/m68k/wrap rm -rf c/src/exec/score/cpu/sh/wrap rm -rf c/src/exec/score/cpu/sparc/wrap rm -rf c/src/exec/score/cpu/unix/wrap patch -p1 < rtems-rc-19991123-rc-1.diff ./bootstrap Known bugs: * "make debug|profile" in c/src/src/score/cpu/<RTEMS_CPU/Makefile does not handle recursion to subdirectories correctly (recurses too often). However, this issue is hardly visible and should be tolerable for the moment.
* Missed in previous automake conversion patches from Ralf CorsepiusJoel Sherrill1999-11-231-0/+18
| | | | <corsepiu@faw.uni-ulm.de>.
* Patch rtems-rc-19991117-4.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-11-221-1/+1
* Applied patch rtems-rc-19990820-6.diff.gz fromJoel Sherrill1999-09-071-1/+1
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-07-262-25/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | This patch is an addition to "The big-patch" CHANGES: * FIX: c/Makefile.am: bogus comment which changed the behavior of c/Makefile.am removed * FIX: make/custom/ts_i386ex.cfg did not set HAS_NETWORKING correctly (Me thinks it might have been me who added this bogus setting :-). * NEW: removing make targets get, protos, debug_install, profile_install * NEW: replacing clobber with distclean * NEW: Reimplement distclean and clean as reverse depth first make targets (adaptation to automake's behavior) * NEW: removing RCS_CLEAN from make distclean (tools/build/rcs_clean is still in - remove it?) * NEW: "$(RM) Makefile" added to make distclean (adaptation to automake's behavior) * NEW: "$(RM) config.cache config.log" to CLOBBER_ADDITIONS in [lib|exec|tests]/Makefile.in (adaptation to automake's behavior) * NEW: "$(CLEAN_PROTOS)" removed (Not used anywhere) * NEW: binpatch.c moved from i386 bsp tools to tools/build (AFAIS, binpatch is not specific to the pc386 BSP at all) * NEW: AC_EXEEXT added to all configure scripts which contain AC_PROG_CC (Cygwin support) * NEW/Experimental: An experimental implementation of temporary installation tree support in libbsp/i386/pc386/tools/Makefile.am, based on dependency tracking with make, instead of applying INSTALL_CHANGE. REMARK: * This patch is small in size, but changes the behavior of "make clean|distclean|clobber" basically. * This patch does not alter building/compiling RTEMS, ie. there should be no need to rerun all "make all" building tests. KNOWN BUGS: * make RTEMS_BSP="..." distclean in c/ runs "make distclean" in BSPs subdirectories passed through RTEMS_BSP and in "c/." only, but does not descend into other BSP subdirectories previously configured with different settings of make RTEMS_BSP="...". => Workaround: always use the same setting of RTEMS_BSP when working inside the build-tree. * "make [distclean|clean]" do not clean subdirectories, which have been configured at configuration time, but which are not used due to make-time configuration (e.g. macros/networking/rdgb subdirectories). This will problem will vanish by itself when migrating from make-time to configuration-time configuration APPLYING THE PATCH mv c/src/lib/libbsp/i386/pc386/tools/binpatch.c tools/build patch -p1 < rtems-rc-19990709-2.diff autogen
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to address this:Joel Sherrill1999-04-192-24/+30
| | | | | > * RTEMS's 'make depend' isn't a standard automake make target and is not > supported in automake supported subdirectories.
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-04-122-16/+30
* Automake II patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. EmailJoel Sherrill1999-03-232-0/+70
description follows: Description: * automake for *all* tool subdirectories (Makefile.am, configure.in etc.) * autogen now also considers CONFIG_HEADER (generates stamp-h.ins and config.h.ins) * c/src/tests/tools/generic/difftest and c/src/tests/tools/generic/sorttimes generated by configure scripts * c/update-tools/ampolish, beautifier for Makefile.ams, similar to acpolish * rtems-polish.sh added to c/update-tools/ + ampolish support * New subdirectory ./automake, contains automake -Makefile fragments to support RTEMS make "debug, debug_install, profile, profile_install" for native Makefile.ams (== ignore these make targets). * aclocal/rtems-top.m4's RTEMS_TOP now reads the automake makefile variable VERSION from RTEMS ./VERSION file. * ./configure.in uses the macros from aclocal + support for the tools' configure scripts Remarks: * To run rtems-polish.sh, "cd <rtems-source-tree>; ./c/update-tools/rtems-polish.sh" * AFAIS, now all native subdirectories are converted to automake (Please drop me a note, if I forgot something). * Unless you notice something fatal, IMO the time has come for a public try (== snapshot). I do not intend to send more automake related patches within, say 2 weeks, to give these patches time to settle and to give me some time to think on how to continue. * The patch assumes installation to the new main installation directory [$(prefix)].
