which is described below:
break something.
SUBDIRS in a Makefile.am)
* An update to gensh2.cfg.
cd <srcdir>
bugs.
rm -rf c/src/exec/score/cpu/i960/wrap
rm -rf c/src/exec/score/cpu/m68k/wrap
rm -rf c/src/exec/score/cpu/sh/wrap
rm -rf c/src/exec/score/cpu/sparc/wrap
rm -rf c/src/exec/score/cpu/unix/wrap
patch -p1 < rtems-rc-19991123-rc-1.diff
./bootstrap
Known bugs:
* "make debug|profile" in c/src/src/score/cpu/<RTEMS_CPU/Makefile does
not handle recursion to subdirectories correctly (recurses too often).
However, this issue is hardly visible and should be tolerable for the
moment.
<corsepiu@faw.uni-ulm.de>.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
CHANGES:
c/Makefile.am removed
still in - remove it?)
(Cygwin support)
REMARK:
inside the build-tree.
APPLYING THE PATCH
autogen
> * RTEMS's 'make depend' isn't a standard automake make target and is not
> supported in automake supported subdirectories.
preparations for automake.
* aclocal/rtems-top.m4:
description follows:
Description:
config.h.ins)
acpolish
configure scripts
Remarks:
[$(prefix)].
