line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
* automake/compile.am: Remove (Unused).
* automake/lib.am: Remove (Unused).
* configure.ac: Remove make/custom/Makefile.
* Makefile.am: Cosmetics.
* automake/compile.am: Remove compilation rules.
Remove $(ARCH) directory generation.
* aclocal/bsp-arg-enable.m4, aclocal/bsp-configure.m4,
aclocal/bspopts.m4, aclocal/canonicalize-tools.m4,
aclocal/check-bsp-cache.m4, aclocal/check-cxx.m4,
aclocal/check-itron.m4, aclocal/check-multiprocessing.m4,
aclocal/check-networking.m4, aclocal/check-newlib.m4,
aclocal/check-posix.m4, aclocal/check-rdbg.m4,
aclocal/check-tool.m4, aclocal/env-rtemsbsp.m4,
aclocal/gcc-isystem.m4, aclocal/gcc-pipe.m4,
aclocal/gcc-specs.m4, aclocal/i386-gas-code16.m4,
aclocal/path-perl.m4, aclocal/ppc.m4,
aclocal/prog-cc.m4, aclocal/prog-ccas.m4,
aclocal/prog-cxx.m4, aclocal/prog-gnat.m4,
aclocal/rtems-debug.m4, aclocal/rtems-flags.m4,
aclocal/rtems-test-no-pause.m4, aclocal/target.m4:
Remove (Unused).
* automake/leaf.am, automake/force-preinstall.am:
Remove (Unused).
* automake/local.am, automake/host.am: Remove "debug".
* automake/local.am: Remove $(ARCH), clean-local.
PR 321:
* aclocal/check-bsp-cache.m4: Remove support for profile-variant.
* aclocal/env-rtemsbsp.m4
* automake/host.am
* automake/local.am
* aclocal/check-cxx.m4: Remove LIBSUFFIX_VA.
* automake/compile.am: Remove LIBSUFFIX_VA.
Merger from rtems-4-6-branch.
* automake/compile.am: Remove CLEAN_DEPEND (Unused).
Remove CLOBBER_DEPEND (Unused).
* automake/local.am: Remove distclean-local.
* automake/compile.am: Remove creating $(ARCH) in compilation rules.
* automake/compile.am: Rework *FLAGS, AM_*FLAGS handling.
* automake/compile.am: Remove hard-coded *_PROFILE_V.
Add autoconf-supplied CPU_CFLAGS, CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V,
CFLAGS_PROFILE_V.
Remove CPPFLAGS_GCC.
* automake/compile.am: Remove LDFLAGS_INCOMPLETE.
Remove LDFLAGS.
Add CCAS, CCASCOMPILE.
Remove compilation rules for *.cpp, *.cxx, *.C.
Use CCASCOMPILE to compile *.S.
Add -pg to RTEMS_CFLAGS_PROFILE_V.
* automake/compile.am: Remove LD_PATHS (Unused).
* aclocal/check-newlib.m4: Adaptation to autoconf-2.5x (AC_TRY_LINK
is announced obsolete).
* automake/compile.am: Remove CFLAGS_DEBUG_OPTIMIZE_V,
CXXFLAGS_DEBUG_OPTIMIZE_V, LDFLAGS_DEBUG_V, CFLAGS_DEFAULT.
Support @CFLAGS@, @CXXFLAGS@.
* automake/compile.am: Remove rel rule.
* aclocal/bsp-configure.m4: Add RTEMS_CHECK_MULTIPROCESSING.
* automake/compile.am: Add test -d $(ARCH) || mkdir $(ARCH) to all
compilation rules (Work-around to an automake bug).
* automake/lib.am: Add test -d $(ARCH) || mkdir $(ARCH) to
make-library.
* automake/multilib.am: Remove.
* Makefile.am: Reflect change above.
* automake/compile.am: Remove GCC272 support.
Remove *.sh rule (unused).
Remove ENABLE_LIBCDIR.
* automake/compile.am (LINK_LIB_RTEMS): Removed line continuation for
last line to eliminate 100's of warnings.
* aclocal/check-newlib.m4: Apply AS_IF.
* aclocal/config-subdirs.m4: Remove _RTEMS_PUSH_BUILDDIR,
_RTEMS_POP_BUILDDIR, _RTEMS_GIVEN_INSTALL, _RTEMS_SUB_SRCDIR.
* aclocal/subdirs.m4: Fix comments, apply AS_IF.
* aclocal/sysv-ipc.m4: Reflect autoconf-2.5x canonicalization
changes.
* aclocal/target.m4: Add _RTEMS_PUSH_BUILDDIR, _RTEMS_POP_BUILDDIR,
* automake/compile.am: Remove librtemsall from LINK_FILES.
changes.
* configure.ac: Reworked for multilibs, reflect changes to aclocal/*.m4.
* aclocal/subdirs.m4: New file.
* aclocal/multi.m4: New file, adopted from autoconf-2.52 w/
modifications.
* aclocal/check-posix.m4: Apply AS_IF.
* aclocal/config-subdirs.m4: Reflect changes to other m4-macros.
* aclocal/env-rtemsbsp.m4: Add PROJECT_INCLUDE, PROJECT_RELEASE.
Add AM_CONDITIONAL(MULTILIB). Adapt GCC_SPECS to multilibs.
* aclocal/env-rtemscpu.m4: Remove RTEMS_BSP. Add support for
MULTIBUILDTOP, MULTISUBDIR. Adapt GCC_SPECS to multilibs.
Add PROJECT_INCLUDE, PROJECT_RELEASE, includedir, libdir.
* aclocal/multilib.m4: Fix m4-quoting, adopt automake-1.5's
OUTPUT_COMMANDS.
* aclocal/project-root.m4: Remove PROJECT_INCLUDE, PROJECT_RELEASE.
* aclocal/rtems-debug.m4: Minor cleanups.
* aclocal/rtems-top.m4: Minor cleanups.
* automake/compile.am: Further steps towards automake's rules.
* automake/multilib.am: include @RTEMS_BSP@.cfg, cleanup.
* automake/lib.am: Add MULTISUBDIR.
* automake/force-preinstall.am: New file.
* aclocal/ppc.m4: New file.
* Adopt more automake rules:
* automake/compile.am: Add LINK, CXXLINK, AS, ASCOMPILE;
Remove ARFLAGS, LINK.c, COMPILE.S, LINK.cc;
Add CPU_CFLAGS to CXXFLAGS, CFLAGS, ASFLAGS;
* automake/leaf.am: Add CXXLINK_APP, LINK_APP, make-exe, apply
CXXLINK_APP in make-cxx-exe.
* automake/lib.am: Add ARFLAGS.
* automake/compile.am: Fundamentally reworked compilation rules for
closer adaptation to automake's behavior.
* automake/lib.am: Comment out LD.
* Makefile.am: Use ACLOCAL_FILES = to make automake-1.5 happy; Add
automake/leaf.am to AUTOMAKE_FILES.
* automake/leaf.am: New file.
* README.cdn-X: Update.
* automake/compile.am: Remove -ansi -fasm from CFLAGS_DEFAULT, add
@CPPFLAGS@ to CPPFLAGS.
* aclocal/enable-rtemsbsp.m4: Split out RTEMS_ENV_RTEMSBSP,
RTEMS_ENV_RTEMSCPU.
* aclocal/env-rtemsbsp.m4: New file for RTEMS_ENV_RTEMSBSP, add
special treatment for GCC_SPECS.
* aclocal/env-rtemscpu.m4: New file for RTEMS_ENV_RTEMSCPU, add
* aclocal/bsp-enable-arg.m4: New file, introduce RTEMS_BSP_ARG_ENABLE.
* aclocal/prog-cc.m4: Add AC_PROG_CPP, use build_os in GCCSED hack.
* automake/compile.am: New treatment of CPP, GCCSPECS, use `..`
instead of $(shell ..) for LIBC_LIB*.
* automake/compile.am: Add LD.
* automake/lib.am: Add LD.
* configure.in: New, Cygnus/GNU style configuration.
* Makefile.am: Add macros/, reflect new configure.in,
ACLOCAL_AMFLAGS = -I $(RTEMS_TOPdir)/macros
* automake/compile.am: BSP_SPECS, remove RTEMS_CANONICALIZATION.
* automake/lib.am: Remove RTEMS_CANONICALIZATION.
* macros/tool-prefix.m4: Remove.
* macros/target.m4: Remove RTEMS_CONFIG_SUBDIRS, RTEMS_OUTPUT_SUBDIRS.
* macros/enable-rtemsbsp.m4: Add RTEMS_CONFIG_PER_BSP, add setting
RTEMS_ROOT.
* macros/i386-gas-code16.m4: Define NEW_GAS only for 16bit mode-
* macros/multilib.m4: Various minor fixes.
* macros/project-root.m4: Remove setting PROJECT_TOPdir,
PROJECT_ROOT, RTEMS_ROOT.
* macros/rtems-top.m4: Remove RTEMS_CANONICALIZATION, TARGET_SUBDIRS;
Add with_target_subdirs, PROJECT_TOPdir, PROJECT_ROOT.
* automake/multilib.am: New file.
* Makefile.am: Update AUTOMAKE_FILES to reflect the contents of
the automake/ directory.
* macros/enable-hwapi.m4: Removed.
* aclocal/rtems-top.m4, automake/compile.am, automake/lib.am:
A small cleanup step towards gnu-canonicalization.
* automake/lib.am: Remove leaf.cfg.
* aclocal/rtems-top.m4: Add ENDIF-hack.
* automake/compile.am: Add include $(DEPENDS) + ENDIF-hack.
* aclocal/check-cxx.m4: Add AC_SUBST(CPLUS_LD_LIBS)
* aclocal/prog-cc.m4: Cleanup comments, require RTEMS_ENABLE_GCC28,
add automake conditionals RTEMS_USE_GCC, RTEMS_USE_GCC272.
* automake/compile.am: Replaced.
* automake/local.am: Remove building variant handling.
* aclocal/enable-rtemsbsp.m4: Add RTEMS_ENABLE_BARE,
AC_SUBST(BARE_CPU_MODEL),AC_SUBST(BARE_CPU_CFLAGS).
* aclocal/i386-gas-code16.m4: AC_DEFINE NEW_GAS.
* aclocal/target.m4: Cleanup comments
* Automake/compile.am: Add DEFS support to keep building happy.
* automake/compile.am: New file
* ChangeLog: Fix email addresses
which is described below:
break something.
SUBDIRS in a Makefile.am)
* An update to gensh2.cfg.
cd <srcdir>
