2018-12-14 | build: Remove ampolish3 | Sebastian Huber | 1 | -274/+0 | |
Update #3254. | |||||
2017-11-27 | ampolish3: Remove reference to bsp_specs in comment | Joel Sherrill | 1 | -1/+1 | |
Updates #3520. | |||||
2015-08-01 | ampolish3: Use env to find perl more reliably | Nick Withers | 1 | -1/+1 | |
Fixes breakage on at least FreeBSD. closes #2379. | |||||
2014-08-29 | bootstrap: Sort the various hash keys used in generating preinstall.am. | Chris Johns | 1 | -4/+4 | |
Something must have changed in perl to change the way the keys are ordered by default. | |||||
2012-05-11 | Remove CVS Id Strings (manual edits after script) | Joel Sherrill | 1 | -3/+1 | |
These modifications were required by hand after running the script. In some cases, the file names did not match patterns. In others, the format of the file did not match any common patterns. | |||||
2007-01-08 | 2007-01-08 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -1/+1 | |
* ampolish3: Use MKDIR_P instead of mkdir_p. | |||||
2006-11-15 | 2006-11-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+0 | |
* ampolish3: New. | |||||
2006-06-29 | 2006-06-28 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+0 | |
* ampolish3: New. * aclocal/rtems-ampolish.m4: Reflect using in-sourcetree ampolish3. | |||||
2006-06-29 | 2006-06-28 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -6/+7 | |
2006-01-14 | 2006-10-14 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -2/+2 | |
* ampolish3.in: Check Makefile.am for SUBDIRS. Add all-am: for PREINSTALL_FILES. | |||||
2006-01-12 | 2006-10-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -10/+18 | |
* ampolish3.in: Add all: for PREINSTALL_FILES. Add all-local for TMPINSTALL_FILES. Misc bug fixes. | |||||
2006-01-12 | 2006-10-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -2/+20 | |
* ampolish3.in: Check if Makefile.am already contains CLEANFILES or DISTCLEANFILES. | |||||
2006-01-10 | 2006-10-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -100/+106 | |
* ampolish3.im: Update. | |||||
2005-10-25 | 2005-10-25 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -2/+2 | |
* ampolish3.in: Sync with private bleeding-edge . | |||||
2005-10-24 | 2005-10-24 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -2/+2 | |
* ampolish3.in: Use @PERL@, partial update from local sources. | |||||
2005-10-24 | New. | Ralf Corsepius | 1 | -0/+243 | |
