2007-01-08 | 2007-01-08 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -1/+1 | |
* ampolish3: Use MKDIR_P instead of mkdir_p. | |||||
2006-11-15 | 2006-11-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+0 | |
* ampolish3: New. | |||||
2006-06-29 | 2006-06-28 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+0 | |
* ampolish3: New. * aclocal/rtems-ampolish.m4: Reflect using in-sourcetree ampolish3. | |||||
2006-06-29 | 2006-06-28 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -6/+7 | |
2006-01-14 | 2006-10-14 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -2/+2 | |
* ampolish3.in: Check Makefile.am for SUBDIRS. Add all-am: for PREINSTALL_FILES. | |||||
2006-01-12 | 2006-10-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -10/+18 | |
* ampolish3.in: Add all: for PREINSTALL_FILES. Add all-local for TMPINSTALL_FILES. Misc bug fixes. | |||||
2006-01-12 | 2006-10-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -2/+20 | |
* ampolish3.in: Check if Makefile.am already contains CLEANFILES or DISTCLEANFILES. | |||||
2006-01-10 | 2006-10-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -100/+106 | |
* ampolish3.im: Update. | |||||
2005-10-25 | 2005-10-25 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -2/+2 | |
* ampolish3.in: Sync with private bleeding-edge . | |||||
2005-10-24 | 2005-10-24 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -2/+2 | |
* ampolish3.in: Use @PERL@, partial update from local sources. | |||||
2005-10-24 | New. | Ralf Corsepius | 1 | -0/+243 | |
