path: root/ampolish3 (follow)
* bootstrap: Sort the various hash keys used in generating preinstall.am.Chris Johns2014-08-291-4/+4
| | | | | Something must have changed in perl to change the way the keys are ordered by default.
* Remove CVS Id Strings (manual edits after script)Joel Sherrill2012-05-111-3/+1
| | | | | | These modifications were required by hand after running the script. In some cases, the file names did not match patterns. In others, the format of the file did not match any common patterns.
* 2007-01-08 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2007-01-081-1/+1
| | | | * ampolish3: Use MKDIR_P instead of mkdir_p.
* 2006-11-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2006-11-151-0/+276
* ampolish3: New.
